Question about GE Dishwashers
16 year old GE built-in dishwasher, model GSD900. Springs that prevent front door from falling disconnected. ALL parts APPEAR to be in good condition. I say appear in good condition because I don't know what they are supposed to look like. But I see nothing obviously broken. The 2 springs appear intact. The connecting cable is good. However one of the 2 springs is shorter than the other. It may be shorter because one is supposed to stretch to the other side of the dw? So number 1 ? is: Why is one spring shorter? The springs are on the left side near the floor. Number 2 ?: Where does the other end of the cable connect to? I know the part of the cable with the 2 holes connects to the 2 cables. But where does the other end of the cable connect?
5 Suggested Answers
  • 409 Answers
SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
Posted on Sep 23, 2008
  • 258 Answers
SOURCE: door springs broke
I have just changed mine and posted the solution with pictures here http://www.howtofixanything.co.uk/howto-260.html
Posted on Mar 08, 2009
  • 33 Answers
SOURCE: GE GSD900L-02 Door spring cable broke
Get 2 of the same springs part # PS259673
DOOR SPRING (YELLOW) (Heavy Duty Door Spring)
Posted on Sep 12, 2009
your_applian
  • 15 Answers
SOURCE: no spring in door
Hi there Mathew, yep your diagnosis sound correct to me the LG dish washers have a string with a plastic lug that conects them to the springs. The plastic lugs and known to brake off the part number for the replacement strings is 4933ED3002A you will need two of these one per side. I hope you find this usefull please contact me if you need any further asistance. Regards Gary.
Posted on Nov 24, 2011
How to replace door springs on lg model LDF6810ST
Found advice from another post for same prob..not tried yet says its not springs but spring cable, part #4933DD 3001B and 2 needed. Poster seem to know what he was talking about
Mar 02, 2013 | LG LDF6810ST Stainless Steel Built-in...
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Our LG dishwasher is about a year old and the door use to stop about 1/3 open when you open it, Now the door just freely goes down and I am not sure why. Can you help?
Hi
Your machine should be under warranty as it is less than two years old. Call LG and see what they say.
Otherwise if you do not have warranty here is a possible solution...
LG Dishwashers have a rope attached to the bottom of both sides of the dishwasher door and the rope winds around a pulley fixed on the side wall/chasis. The other end of the rope is hooked to a spring tensioner which sits vertically along the side of the machine.
Either one or both ropes may have broken as the ends have a plastic catch which normally break. Sometimes they need tensioning or they fall out of the pulleys.
It is a major job to get to them and if you are prepared to do this you need to be handy.
In order to get to them you need to disconnect and pull the machine out. Remove top cover, either two screws at the back or in front depending on the model. Then remove plastic kick board in front bottom of machine. These are clipped on. When you remove this there is another white plastic front cover with front legs attached to it. Remove the front screws on either side to pull this part off. Sometimes the wire harnessing is attached to this part and you need to unscrew before you pull it out.
Once you remove this follow the screws all aound the side panels both in front and at the back of the machine to remove panels. When you remove these you can look at the sides. Open and close the door to observe the door pulley mechanism I described. If the rope is not torn, Just look to the top of the springs, there is a screw which gives more tension to the springs. Tighten the screws and see if this rectifies the problem. Otherwise you need to order the brocken parts.
Good luck
Ash
Sep 09, 2011 | Dishwashers
The door just flys open and slams down with no support. Won't stay closed unless pushed in all the way.
I'm no sure why the door is flying open but it the door is falling without any tension, it sounds like 1 or both of the cheezy nylon lines that hold the door springs or their plastic accessories have bit the dust. Look at page 24 of your installation instructions if you have them. Shows what they look like. If you pull the dishwasher out, you will see them in the front on the lower left and right. Our dishwasher is 7 years old and they have broken twice now.
Nov 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Sep 12, 2009 | GE Dishwashers
38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Jul 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
DOOR REPLACEMENT
On most dishwashers the front panel is removable/replaceable. You can try www.coastparts.com or www.marcone.com .
Dec 07, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Mdb7601aws dishwasher door drops down
hi there,
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
42 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
