Question about Casio Watches
What is the secret for replacing the Cover End Pieces (plastic part) on a men's Casio G Force watch? It looks like I should just remove the side screws but they turn and turn but never actually loosen.
  • 40 Answers
SOURCE: Caravelle by Bulova watch strap adjust
You need to push the pins out in the direction of the arrows. Then take out one link from each side. Put the pins back in the same way they came out, with the slot pointing the same direction as before.
Posted on Feb 26, 2007
SOURCE: Changing links for a Casio watch bracelet
solutions already mentioned(casio wristband) worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB547b9a0.jpg
Posted on Dec 30, 2007
upajos
  • 24 Answers
SOURCE: For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
Posted on Sep 01, 2009
  • 12 Answers
SOURCE: casio edifice mens watch user instructions needed
Go in alarm mode by pressing the mode button once twice...depending on the modes you have and then press one of the remaining buttons, usually top right button on most edifices. this toggles between alarm on and off. this shall do....
Posted on Oct 04, 2009
escapement
  • 2334 Answers
SOURCE: POD watch battery replacement.
Unscrew the screws holding that contact. Memorize where each screw was - they can be different in length. Fit new battery, put contact back in place and screw all screws back exactly where they were. After that you may need to shortcut battery's+ and AC point (marked on movement) for resetting your watch. Use tweezers to do that. Rate me, plz.
Posted on Feb 02, 2010
How do i do this.After battery replacement, contact AC with (-) using tweezers
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Sep 19, 2014 | Casio wave ceptor WV200A-1AV Wrist Watch -...
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
BRegards
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
I need to no how to set the time on my watch
you need to look at the user manual.
just write the code on the back side and click searched on the URL below which you can also
download a soft version of the user manual .
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Sep 08, 2011 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
How do i set my casio giez gs-1001 watch
it is a complicated issue and you need to look at the user manual.
Thanks
Aug 24, 2011 | Casio GShock GShock Giez GS10012ADR AA...
I have a Casio (593 F91W) and cannot get the pins out to change band. Jeweler cannot get the pins out. What is the secret?
It's likely that your band pins are thin and do not have collars that can easily be grabbed by most band removal/installation tools. If you are already changing the band, the best thing to do would be to cut off the band so that the pins are clearly visible, then use a set of nipping pliers to cut the band pins in the middle. At best, you'll cut them in half; at worst, you'll bend the pins into a "V" that will pull at least one end out of their holes. Obviously, you'll need fresh pins with your new watch band.
Efforts to dig the pins out of their holes can easily damage the holes themselves, making the watch useless.
Apr 26, 2011 | Casio Classic Black Digital #F91W1 Watch...
How to adjust the analog time of watch casio iluuminator / thanks
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
Mar 23, 2011 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
New watch - how to start it - battery?
mcdevito75 here, Brand new watch. If it has a stem, (winder) look for a small piece of plastic between the stem and case, remove this piece of plastic and push down the stem to start your watch. If your watch is all buttons, look for a small plastic tab on the back cover, remove this plastic tab and your watch will start.
Sep 20, 2010 | Adidas Response Light Twin watch #ADP1701...
How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
Thank you for contacting FixYa.
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How do I manually adjust the time or force the communication with the atomic timekeeper?
    You can get instructions from the Casio web site.
    Go to the casio web site "casio.com".
    Select "support" and the "manuals", watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Click on "search" and the download your instructions.
    Mar 15, 2010 | Casio GShock Atomic Solar #MTG910DA1V...
    Watches Logo
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
