Question about Tamron 70-300mm f/4-5.6 Di Zoom Lens for Canon AF Cameras
Tamron AF 70-300 4-5.6 LD macro1:2. Had problems with old 350D body (error[?])..with new 60D body..'lens failed to communicate with camera'..(or words to that effect)..with 60D, lens will work if aperture is set to largest/lowest f no. On 350D, lens failed if zoomed up to higher mag.(towards 300mm). Contact clean, everything else seeming ok. Any ideas~ what can I do? Pity nice lens..can't afford to buy other at moment. What might I be able to do, if anything, to rectify problem? Many thanks, Simon. spj747@yahoo.co.uk
SOURCE: Tamron 28-300mm lens
Many zoom lenses of this length, and even shorter have the problem whereby the lens either extends or retracts under its own weight depending on whether the camera is pointing up or down. I had a Canon 28-105mm lens with this problem. More expensive lenses have zoom locks to prevent this from happening. $225 sound like a good price to me!
Posted on Oct 19, 2007
cammedic
  • 667 Answers
SOURCE: tamron 28-300mm lens disassembly help
Both, But start at the rear to remove the electronics and the outer barrels. Remove any rubber grip to expose 'hidden screws'. I would mark everything or document with pictures during disassembly.
Posted on Jan 29, 2008
cammedic
  • 667 Answers
SOURCE: Tamron 70-300mm lense
Make sure the aperture ring is set to the minimum f-stop number, ie f22,f32. It is usually colour coded orange
Posted on Feb 16, 2008
SOURCE: Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Posted on Jul 05, 2008
SOURCE: Sigma 70-300mm lens not fitting Canon EOS 350D
Are you sure you bought a lens with Canon AF mount? To me it sounds like you got one with a mount for a different camera.
Does the mount on the lens look like this?
If it doesn't, you got the wrong version of the lens. If it does look like the mount in the picture, your just mounting it incorrectly.
If you hold the camera with the lens mount facing you, the red marker on the lens should be in the 12 o'clock position, lining up with the red marker on the lens mount on the camera. The turn the lens clock wise, about an 8'th of a full turn, and the lens should click into place.
I hope this help you!
/Chris
Posted on Jan 19, 2009
Is a tamron 28-300 F/3..5-6.3 AFC adaptable to my canon T3I?
Tamron makes their lenses with a variety of camera mounts. If the lens has a Canon mount then it will work fine on your T3i. If it has another mount then it will need an adapter, and you will lose some functionality (probably autofocus and autoexposure).
Jul 05, 2014 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
Error 99 with a Canon 300D (original rebel) and Tamron XR Di II 18 to 200 mm lens. Occurs when lens is zoomed out. Does not happen with other lenses (Canon 18-55 kit, Canon 75-300). Cleaning contacts on...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Apr 17, 2011 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
I have a tamron 70-300mm i had a canon 1000d and the lens worked pefectly fine with it but nw i hav purchased canon 550d and when i conect my tamron lens with it , it shows an error 01 please assist me
This is the kind of error which you always risk these days in buying lenses which are not from your camera manufacturer. Error 01 simply means that the camera cannot communicate with the lens. Canon's protocols are not open standards and third party manufacturers have to reverse engineer to produce something which works. As they're working in the dark, they cannot always arrive at a solution which makes all models suit all Canon bodies.
You have two possible solutions:-
Visually inspect the contacts on the lens and the camera body and if they're anything other than clean and bright then use a clean pencil eraser on them. Be very, very, careful not to let any of the rubber crumbs into the lens or the camera body.
If that fails, visit the Tamron website to see whether the lens can be returned to be updated for other bodies. if it can't then sell it and buy a later Tamron model or better still a Canon one. They may cost more, but the results are better and their resale value is much higher.
Mar 07, 2011 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
I was told by pentax that my tamron lens is no good for my pentax camera.I would like to know why .My camera is two years old and has been sent back to pentax four times .they tell me the problem is my...
Absolutely. Pentax only guarantee compatibility of their cameras with their own lenses as long as they're contemporary to the model you're using.
Other manufacturers make lenses which will physically fit your camera, but now that all communication between the body and lens is electronic they're not always fully compatible especially as the camera manufacturer often changes the technical specifications.
Check with Tamron: it's not unusual to have to send your lens back for an update to ensure compatibility with the latest models.
Jun 16, 2010 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Error 01 tamron lens 70-300 mm af 4-5.6 with canon dslr 450d
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
May 28, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Tamron 70-300mm f/4-5.6 Di Zoom Lens for Canon AF Cameras Logo
80 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
