Question about Liebherr KIB 2544 Premium BioFresh Top Freezer Refrigerator
Door seal no longer efficient. Can you help - Liebherr KIB 2544 Premium BioFresh Top Freezer Refrigerator
    Problem Solver:
  • 7 Answers
Get some scotch tape and inbetween uses wrap a load of the stuff round and round the fridge, That should keep the door closed. For ease of use keep a stanley knife nearby so you can get at your food etc
Posted on Mar 11, 2011
GE TBX25R refrigerator not cooling. Found thick ice on freezer coils on the mid to upper half. The defrost heater is working, no ice closest to coils and tested the element. Help!
You say the defrost heater is working, but does it switch off at the end of the defrost cycle?
A refrigerator is a closed box and the only water vapour to condense and freeze to produce ice should be from the food and the opening of the door. Remember the days before auto defrost when a fridge in good order needed defrosting only a couple or three of times each year? That is a normal ice build up.
A freezer needed less deicing than that.
Excessive ice signals the possibility of an insulation failure (search for cold areas on the outer casing) a bad door seal, an auto defrost malfunction or possibly a general decline in the efficiency of the cooling system due to a worn compressor or lack of refrigerant - an ice build up in the freezer only means the temperature is below freezing, you didn't mention what the freezer temperature actually is but I wager it is far above the minus 18 - 27 degrees C of an efficient freezer.
One method of judging the efficiency of a refrigeration system - the purpose of which is to move heat from the inside of the cabinet to the outside where it is dispersed by the condenser which will naturally become quite warm. If the condenser isn't as warm or even almost hot as usual while the compressor is running then it isn't efficiently moving heat from inside the cabinet.
Generally a lack of efficiency tends towards longer than usual compressor cycling and even constant running.
Oct 25, 2017 | GE Refrigerators
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
Howh do i replace the gasket pad
Nancy,Could not find instruction for seal removal on your particular model, did post links to models, hoping they will be close/same as yours. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Door Seal part WP3405245 How To Replace
How To Replace Torn Or Worn Out Dryer Door Seal
Dryer Door Seal part 33002094 How To Replace
Jul 10, 2016 | Maytag MDE2400AYW 24 High-Efficiency...
Could Split in door seal cause machine to take an hour longer to go through programme?
Sounds like you have a blocked pump. The door seal is a red herring
Jan 16, 2016 | Bosch Washing Machines
Leak around the door seal
the seal might look ok but don't forget the seal could crack on the bottom, any time the washing machine stops and the water settle
there's more water at the bottom half so the bottom of the seal takes more abuse. so I would replace the sealer and if you can buy a little thicker one.
Feb 07, 2018 | Samsung WF218ANW 4.0 cu. ft. High...
Door leaking
This video will show you how to change a door seal on this Bosch front loader washing machine
Dec 21, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a high efficiency front load kenmore washer that leaks around the front door. How do I fix this?
You may have to replace the door bellow (gray rubber seal). These seals can become mishapened or develop rips or tears over time and no longer seal. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Nov 27, 2009 | Dishwashers
Shelf locators broken of the back the freezer on kelvinator impression series 500l
hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
Oct 17, 2008 | Refrigerators
GE front loader washer soap inside door
You can try using soap powders for 'front loading' machines......
Mar 03, 2008 | GE WSXH208A Front Load Washer
Liebherr KIB 2544 Premium BioFresh Top Freezer Refrigerator Logo
465 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
