Question about Akai MPK mini MIDI Controller Keyboard, 25-Key
Is the MPKmini compatible with sony music studio8
It should work as a generic midi controller if it isn't listed
Posted on Apr 13, 2011
Looking for a sustaining pedal for the Casio ctk 401 keyboard. What models will be compatible?
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Apr 22, 2016 | Casio Music
Floppy disk drive emulator usb
The floppies in most of the music instruments are NOT quite compatible with the USB floppie emulators.
Feb 20, 2011 | Korg Sound Card Disk O1w Fd 01wfd 01 W O1...
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
Just bought Kingston 2GB SD Card for Boss Micro BR but when maching turned on,its frozen on KEEP POWER ON! SONG LOADING!
This is likely a compatibility issue. Turn power off and remove the card and make sure the unit comes back to life.
SD card compatibility can be a problem.
You might want to go to VSPLANET.com as there is a lot of info on forums about recorders.
Jun 03, 2010 | Boss Micro BR Digital Recorder
Compact flash that i bought wont work san disk 4 g ultra says error 9
USUALLY the ultra and high density flash cards have trouble working in most music equipment.
Only buy the cards up to 2 Gb and verify compatibility with one of them before buying more.
May 09, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
When my flash drive is connected to my triton extreme,the files that I want to transfer aren't appearing in the media section of the triton
They are probably either in the wrong format or you are in the wrong mode for the format the files are in.
Also make sure the flash is compatible. There are some problems with the SD and high density SD card compatibility.
Mar 12, 2010 | Music
How do I transfer music data off my korg Triton keyboard's floppy
Either the floppy format of the Triton is not PC compatible or maybe you don't have a floppy drive on your computer? If the latter, buy a USB floppy drive... about $20
Sep 16, 2009 | Music
Open Questions:
Akai MPK mini MIDI Controller Keyboard, 25-Key Logo
193 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
