Question about Epson Office Equipment & Supplies
Epson Artisan 810. Document feeder jams everytime. Cannot print or scan any multiple page document. Is it replacable? repair?
  • 16 Answers
SOURCE: scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Posted on Jan 05, 2008
SOURCE: HP LaserJet 2840 Scanner problem
Yes, but I don't see any actual paper jams. I have a Vista O/S and I've been reading that that might be the problem; the 2840 scanner driver is not compatible with the Vista O/S and HP hasn't produced a solution yet. I appreciate your efforts, thanks.
Posted on Feb 10, 2008
SOURCE: Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Posted on Mar 09, 2008
SOURCE: paper jam in the automatic document feeder
doc. feeder jam
Posted on Aug 07, 2008
SOURCE: paper in document feeder
there is no paper in document feeder
Posted on Dec 01, 2008
Epson 810 printer
It seems you have Eprom malfunction there.
You can flash its Eprom with its new Eprom file or just replace its Eprom chip and everything will back as normal. This is a common problem for this printer especially L series.
This type of printer often showing paper jam while there is no a single paper in its tray and the paper's sensor still working fine.
Hope this will answer your question.
Sep 14, 2017 | Epson Artisan 810 All-in-One Color Inkjet...
Cd/dvd tray failurer in Epson Artisan Allinone injet printer
If you are experiencing this problem, continue as normal to print your clock then choose preferences and ensure your printer settings are ok and that it is set to print to the dvd/cd tray, then proceed to print your clock.
If you are still experiencing problems Try Solution 2..
Instead of changing your printer settings through Clock Designer, change your default printer settings. Go to the control panel in windows and open the printers section. Find the printer you are using (Actual screen shots will vary depending on your version of windows and printer)
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Epson Printer Support
Feb 17, 2014 | Epson Artisan 810 AllInOne InkJet Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
  1. Press <Stop/Reset>.
  2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
  6. Close the Feeder Cover.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    When rescanning the document after clearing the error, rescan it from the first page.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
  3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
  4. Open the Document Cover and pull out the document from the inner side.
  5. Close the Document Cover.
    Note: When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
How do I scan in more than one page to a file? I would like to scan a 5 page document into one file. Can this be done?
You don't list the make and model of scanner, but if it's the type that comes with an automated document feeder, the software usually supports scanning multiple pages. If not, and you are planning to save it as a PDF, you can use Adobe Acrobat's "Scan to PDF" option--I believe it asks you after every scan if you want to combine that page into the same document.
Apr 01, 2010 | Epson Stylus RX500 All-In-One InkJet...
Lines on copy's when using auto document feeder on epson artisan 800
You don't say exactly, but I'm guessing that scanning when laying the document flat on the glass (ie, not using the document feeder) you get a printout that is fine. It's only when you use the document feeder that you get the vertical lines on the printout?
Epson repair tech in my area says this is a common problem. It is due to the aging of the calibration strip (the white strip at the underside of the flat bed glass near the "home" position). It shrinks after years and can't provide correct calibration.
This is a problem only with the pages fed through the document scanner. It sounded weird to me, but the tech said he stocks lots of replacement glass and does lots of these repairs to Epson scanners.
It might be cheaper to buy a new scanner rather than get yours fixed. He said it's pretty inexpensive to do this repair, but scanners are also pretty cheap.
Good luck.
Jan 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Scanning...
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
1,305 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
