Question about Garden
Installed new battery on LT1045 CUB CADET----- Now have no panel lights or instruments and starter only clicks
Make sure the fuse link found in back of instruments did not blow, if so replace and solve problem . But because you also have a starter that clicks I advise you to disconect the negative cable from battery and clean copper with wirebrush, then remove other end and do the same. secondly repeat that with posotive side too. lastly disconect the key switch from its cables, if possible clean contacts and if not just plug them right in again and you should solve the problem.
Posted on Mar 11, 2011
Solenoid clicks cub cadet lt1045 mower won't start. Has new solenoid, starter battery and spark plug
It is possible the starter safety circuit is triggering. This is an interlock to prevent injury when starting and checks for things like driver not on seat, park brake engaged, etc.
Refer page 12 of the manual available on this site if you do not have one.
http://data.manualslib.com/pdf/4/341/34016-cub_cadet/lt1045.pdf?6c17c6482511338711d5965e5bb6681c&take=binary
Apr 23, 2014 | Cub Cadet Garden
Cub cadet lt1045
Did you check voltage on the battery, and did you leave it running at a high idle? (low idle can consume battery voltage instead of charging it.
On many tractors the lights do not run unless the motor is running so don't let that throw you off.
Things to check
Make sure no fuses popped.
Makes sure you have gas
Try jumping it to see if it starts If not, it sounds like you may have a short, or may have a safety switch that is acting up. look for loose, broken, damaged wires.
Check to see if any wires are hot when the battery is fully charged. Try that and repost what you do or don't find.
May 07, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet LT1045 starter solenoid: can 4 prong replace 3 prong?
Yes you can. The small wire from the key switch goes to the prong closest to the power wire from the battery.
Dec 12, 2012 | Garden
STARTER WONT TURN ENGINE SOLENOID CLICKS BATTERY IS FULLY CHARGED
Do you have 12volts dc to your starter when your solenoid clicks?
if not replace solenoid,if yes check starter next and then be sure engine is not siezed?
Apr 30, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Mower has fully charged batt while trying too start it just clicks at the solenoid and then a humming sound but nothing from the starter it self ltx 1042 cub cadet any help would be great thankyou
Sounds like your going to need a new starter. They're not to much you should be able to buy one at your local lawn and garden store, and they're very easy to replace.
Feb 07, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I don't want to talk to an expret , I lost my manual and I need one to repair my Tractor Cub Cadet lt1045
OK, I won't talk :)
Here is the direct link: http://www.hammerwall.com/Download_Manual/13295/ if the link gives you problems do the following.
Go to www.hammerwall.com and put in Cub Cadet lt1045
Jan 14, 2011 | Cub Cadet Garden
I have a cub cadet lt1045 series and I cant get it started
check starter-the starter gear may be stuck or spring may be broken -new doesnt mean free from defects--if starter before working on or removal of parts notify place of purchase should be covered under warranty
Mar 13, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
