Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
We have a 1970 1256 IH tractor that has lost all steering, brakes, and motion (forward and reverse).We put a pressure gage in the port on the multiple control valve and it showed zero on the gage. We drained the oil and visually checked that the pump gear was good and when we bumped the starter it was turning. All seemed ok so we put a new pump on. With the oil topped off we tried it again and still the gage reads zero.It acts like the pump isn't getting any oil. We also changed the hydraulic filter. Not sure which direction to go next. Any help would be greatly apprieciated.
  • 2 more comments
  • cha210 Mar 11, 2011
    The pump is lower than the oil level, the port that the pressure gage is in is where the manual says to put it. the book calls for an operating pressure between 1800-1900 psi. If less than that it says to replace pressure relief valve. We can't get any oil out of the pressure relief hole with the pressure relief valve removed.
    We removed the relief valve completely and left the hole open and don't even get a drop of oil to come out
    Yes that is exactly right, but we figured it out. The only thing we can come up with is it was air locked. We took the multiple control valve (MCV) off again and removed the pump off the plate and when we looked inside the pump it was dry. We remounted the pump to the MCV and poured some oil into the suction side of the pump and turned the gear by hand untill we had oil coming out of the pressure outlet hole(where we had the pressure gage). We reinstalled the MCV to the tractor, topped off the oil again and started the tractor. At first we didn't have any pressure on the gage and then we loosened the fitting on the gage and we got some air and then oil and then the pressure started to build to specs. at the end we had about 1700 psi. Steering works, brakes work and so does forward and reverse. So all we can come up with is it was air locked and without some oil in the pump to fill the air space around the gears in the pump it was just spinning and the oil didn't have enough head pressure to gravity feed to the pump. Hope this all makes sense, in the end we did get it to work, and we thank you for trying to help. Thanks again, Charlie
  • cha210 Mar 12, 2011
    We ended up taking the pump off and pouring oil into the suction hole and turning the pump by hand. An air lock seemed to be the problem.
  • 2,510 Answers
Ensure that the port you use on the multi control valve is in the inlet port passage of the valve.
If your reservoir is lower than your pump, the pump will have to be primed. Try see into the reservoir if there is any flow of fluid when the pump is operating. One of the main causes of lack of pressure in a hydraulic system is a failed pressure relief valve. Check if there is a free flow out of the return port of the valve with the engine and pump running, there should only be a relief flow out of it - try fit the gauge to the inlet side of the valve and observe the pressure there. You can rule out the filter as a problem area.
I am not familiar with your specific hydraulic system but am conversant with much larger and more complex systems. Is it possible to isolate everything in the system bar the reservoir, the pump and the relief valve and a gauge? If you can and it builds up pressure, then you can start including systems until you are without pressure again and this will pinpoint your problem component. Alternatively, isolate systems one at a time (not the relief valve) and try locate your problem this way. I believe your system pressure should be 1600 psi.
Please come back to me with any findings or if you need more information.
Posted on Mar 11, 2011
  • 1 more comment
  • Hans Pearson
    Hans Pearson Mar 11, 2011
    Can you put your pressure gauge on the outlet of the relief valve, cutting out the whole hydraulic system to see if you have pressure there?
  • Hans Pearson
    You mean that you are not getting any delivery from the pump at all, yet is is a new pump and you see the gears moving. Is it possible to connect the pipes the wrong way around on the pump? If it is a gear pump, the normal type with two inter meshing gears, the gears carry the oil around the outside in the tooth pockets and the meshing teeth force the oil out of the outlet ie. if the inlet is say, at the bottom and the outlet at the top and you are looking down on the gears, the left one would be turning clockwise and the right one would be turning counter-clockwise. Come back to me with any further information.
  • Hans Pearson
    Hans Pearson Mar 12, 2011
    Glad that you worked it out and sorry for the long delay, it turned into night here and bedtime. The reason I asked about the location of the reservoir to the pump was for the purpose of priming the pump on start-up. Well done any way. Regards, HANS
  • 18 Answers
On rear of mcv valve will be a plug that uses a5/8 wrench [only one that size] remove it completly start tractor (this is going to make a mess)see if oil sprays out of valve body if it does put plug back steering ta and brakes should work
Posted on Mar 18, 2014
    President:
  • 1,702 Answers
Try putting oil down the pressure relief valve hole, just in case the pump is air locked, we have even used a electric fuel pump to help prime the pump before. also prime the filter before you put it on.
let me know how it works out.
Posted on Mar 12, 2011
  • john nail
    john nail Mar 12, 2011
    good for you those air locks can be a pain.
Husqvarna 4623 zero turn mower will not move
Maintanance - How to purge Hydraulic drive system Published 01/13/2010 11:56 AM ' Updated 06/02/2015 02:52 PM
How do I purge the hydraulic system?
Hydrostatic transmissions use oil, under pressure, to provide movement for the tractor. The fluid is pressurized with a pump inside the transmission. If any air is in the fluid, the pump will try to pressurize air. This condition is known as cavitation, and is detrimental to the pump since it allows the pump top operate dry. When the pump cavitates it is not pressurizing any fluid, so the transmission is not able to provide the movement needed.
If your mower is new, or has been stored for a long period (longer than 2 months) the transmission needs to be purged before use. Also, if you experience loss of drive, or slower response, then the transmission should be purged first.
The following procedure will remove trapped air inside the transmission(s).
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
Aug 06, 2016 | Husqvarna Garden
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
unset the brake push pedal all the way down and release it
Apr 10, 2015 | Garden
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
Have a 706 diesel and it won't always go into reverse, what could the problem be?
I had the same problem with mine. first the most easiest step is to check the adjustment onthe linkage, if it is good then pull the deck plate off and under the plate in front of the steering colum will be a retangular top cover; pull the cover off(it'll be heavy) and check the forward, reverse fork. The forks tend to wear down over time and cause extra movement in the slider gear. Be sure to check the shift rod going through the top cover. I've heard of them egg-shaping into the covercausing excess movement. Hope this helps.
Apr 21, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
My steering on my 806 Farmall gets stiff, but I mash my breaks and it loosens up. What can it be?
More than likely the issue is in the multiple control valve that feeds both the brakes and the steering. It bolts to the left front of the tranny, right under the battery. While you're in there, it's a good time to re-gasket the pump. Buy yourself an I & T book, # IH-32. You'll need it! Also, don't lose the spring and check valve when you pull the control valve off the tractor!
Mar 15, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Apr 18, 2009 | Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
1,300 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
ray gallant
James Gettemy
Are you a Farmall Toy Expert? Answer questions, earn points and help others
