Question about Whirlpool Dryers
Whirlpool dryer I took the back off my dryer to change the belt, I dont see a belt, where is it at? AN HOW DO I GET TO IT? MOD- LER8648LW1
    Genius:
  • 1,028 Answers
Reinstall back.. remove 2 screws under lint screen press 2 clips on front corners with putty knife lift top remove screw on each side top inside front lift front off belt goes over drum ..double it and pass through idler support arm then onto motor pulley ..belt pack may have a diagram
Posted on Aug 01, 2008
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool Mod LER4634JQ0 has stopped working - you can hear the timer clicking, but does not operate on any cycles
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Whirlpool LER4634J Electric Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer LER7646EQ2 Belt
sure he will if not get back to us we will help thanks from gilles
Mar 15, 2009 | Whirlpool LER7646E Dryer
Whirlpool Electric Dryer LEQ88ooJQ1----I think it's the belt.
you have to pop the top and take the front off to change the belt. there is two clips you can press with a putty knife ,about 3 inches from each side on the front under the top . This will release the top. Now check the belt on the drum. If it is whole the problem is the idler pulley . I can help you and supply the parts you need cheap
Dec 14, 2008 | Whirlpool LEQ9858P Electric Dryer
No heat gas dryer
hi look for the thermal fuse at the back where you cleaned . its a small plastic piece with 2 small blue wires . replace this part thanks
Oct 06, 2008 | Whirlpool Dryers
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
85 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
