Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
How do i access circit board for flashing control panel and ice door opening and closing non stop through front panel or inside door please provide step 1 2 3 how to take door apart i have new circut board on hand thanks mod mfi2568aes ser 10289024ja
  • Maytag Master
  • 4,654 Answers
Ric22355, you will begin as follows below. I have much more and may need you to view a larger version of instructions.
If you have more questions please let me know, Thanks, Sea Breeze
Posted on Mar 11, 2011
How do I open the front control panel of my Samsung side by side refrigerator?
I tried to reply on my question, when you asked, I don't think it worked. First of all it sounds like you have a bad control board, or you may have a loose connection. On back of the fridge is your main control board, I think its the first wire at the top to the right, if that wire is disconnected the door will open and close. When I was running some test, I took this wire off and it began to do this. As for taking the display off, simple, took a while to find this out but all you do is take the one screw out, grab the ice shoot and just give it a firm tug, it should pop right out. you have the hose attached and theirs a wire connected so be careful, but that all it takes.
Jun 06, 2015 | Samsung RSG307AARS Stainless Steel Side by...
I HAVE A MAYTAG MFI256B THAT THE ICE DOOR HAS
You have a short inside the key board or the control board for dispinser. Disconnect the pin plug at the upper or lower hinge until we can trace the short. Sea Breeze
Mar 13, 2010 | Refrigerators
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Washer stops
Initially, pls open the lower access panel (bottom of your washer) by removing the 3 torx screws. There would be a sheet that lists the error codes. The panel pulls forward and down, inside mounted on the right side taped to that inner panel would be the above described sheet. Additionally, to my knowledge, this indicates a door latch fault, the machine cannot activate the lock or senses that the door is not closed or the door is not locked.
In some instances, the error code F/DL could be triggered be a loose component. This could be that the plastic fitting on the door is loose and therefore will not latch on the locking assembly or the locking assembly itself is loose. You could then try opening and closing the door a couple of times.
Should this be not corrective, then the logic controller board may require close checking.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
On electronic control panel and water/ice despensor the ice cube door keeps opening and closing and the buttons on the panel do not respond tempratures of fridg and freezer keep flashing. Tried unplugging...
you have a maytag ice and water in door 3 door refrig???? if so you needs a new high voltage board, its gone bad. locatdon back wall behind the refrig. only resolution is to replace the board..
Mar 16, 2008 | Refrigerators
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Panel flashing, ice door opening and closing constantly
I had the same problem, with this model and it was the high voltage control board located in the rear. Replaced the board and it is working OK. Maytag Part # 12920710 will work on this model and it is 40.00 cheaper than the one it shows when you do a parts search. It will come up 12920709. I checked with Maytag and they said 710 will work..
Sep 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
277 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
