Question about Dryers
How do i change my timer - Dryers
Need to no what colour wires go to what numbers on the timer on indesit idv65uk
tumble dryer
Posted on Feb 24, 2012
  • Dryers Master
  • 17,130 Answers
Please make sure that the wiring is not tampered and taken out. Purchase the same type of timer and connect the wires after you have a sketch diagram with the wire codes so that no terminal wiring mistake is done while changing the timer.
Use the colour codes or use wire codes on the wire so that a wrong wiring is not possible.
Posted on Mar 11, 2011
Do i need to power down to change the back up battery
If this is ordinary residential timer, you can replace battery without changing anything.
Just replace battery.
Most timers will hold some or part of the memory during battery changeover... frequently losing no programming if battery change is done quickly, and battery was not completely depleted, and timer is still functional.
If timer function is not restored after battery change, reset timer fully and then reprogram.
If battery change and reset does not work, then timer is probably gone bad.
Most modern timers have reset button, but some require a 2-button sequence to reset.
Other modern timers have a 'battery' but the battery is built into the circuit board and thus not replaceable ... it is rechargeable, like a capacitor ... but when it fails .. the timer needs to be replaced.
Timers with replaceable batteries are generally not functional after exposure to freezing temperatures for several day, but the non-replaceable type generally have wider tolerance for temperature variation.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Programmable.html
Gene
Water Heater Timers Save Money
Mar 23, 2015 | Hardware & Accessories
After a battery change, my timer ET100C flashes 1-h8. What is the cure?
Try resetting timer.
Small round hole located just below the display... use paper clip and push and hold for 5 seconds... then reprogram timer
If functionality is not restored, then replace timer.
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET100
Gene
Feb 27, 2015 | Intermatic 10 Amp Mechanical Indoor Timer
RESET TIMER
Reset the timer after battery change.
If functionality is not restored, then timer could be bad.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Gene
Oct 06, 2014 | Hardware & Accessories
Can i change the model T101P3 timer from 110 to 220?
1) Yes. Change clock motor from WG1570 to WG1573
Wiring is same as T102 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T102
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) If new pump motor is 2-speed, then converted T101P3 cannot handle 2-speed pump.
Use T106 timer, or T1906 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html#pool
3) New T106 or T1906 timer mechanism will snap into T103P enclosure without changing boxes.
Any intermatic timer will snap into Intermatic enclosure.
Other brands of timer can adapt to Intermatic enclosure using Tork IAP adapter bracket.
Mar 10, 2013 | Hardware & Accessories
Outdoor light timer by Intermatic in house when we bought it. Trying to program it after changing batteries, but there are no directions for it. how would I get some instructions for it?
1) Model number is unknown.
2) You have outdoor programmable Intermatic timer, and replaced battery.
3) Open following link to help identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
4) If timer does not show on link above, add a comment with clear description of timer and buttons for possible identification and manual.
5) Most battery operated timers require 'reset' after battery change.
Manuals usually say, the battery is replaced and programs remain intact, and then current time has to be set again.
In typical situation however, most timers lose functionality with battery change. That's why timer is reset, and then reprogrammed.
6) If functionality is not restored after battery change and reset, then timer has gone bad.
7) Newer Intermatic timers have 'lifetime' warranty against workmanship defect.
Older timers have 1 year warranty.
8) Electronic timers, low voltage power packs, plus electronic water heaters, and electronic water softeners and treadmills etc are each susceptible to power surge from nearby lightning and also from simple power outage.
Not always necessary, but safest to unplug outdoor timer during storm event and with circuit breaker trip, or power outage. Plug back in after power is restored or storm is over. This is true also if timer is on GFCI, and breaker trips. Unplug timer and then reset GFCI.
Add a whole house surge protector to main breaker panel. This gives 1-time protection from surge event.
9) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Hardware & Accessories
The self=adjusting wall switch timer does not go on as set but it goes off at the set time, I put in a new battery at the end of May but sometimes the Batt is flashing. The battery sure can't be...
1) Timer is not 100% identified.
Sounds like Intermatic ST01C or Ei600
Sounds like timer needs to be reset after battery change, and then reprogrammed again.
3) Open following links to help identify timer and download manual:
http://waterheatertimer.org/ST01C-program.html#battery
4) If timer does not show on links above, add a comment with clear description of timer and buttons for possible identification and manual.
Manual usually says to replace battery and timer is ready to go again.
However, most timers lose functionality with battery change. That's why timer is reset, and then reprogrammed.
7) Intermatic timer has 1 year limited warranty, and there is not much that can be offered except buy next timer at local store. For example Utilitec 0192773 is actually Intermatic product. Sold at Lowes. If timer goes bad 2 years later, buy another one and return defect in new package.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
8) Take a moment and rate answer:
We need clear instructions for setting the timer
Woods makes several outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Lost the instructions T1032-33-34-35 can we get them?
http://waterheatertimer.org/pdf/Aube-T1032-timer.pdf
Aube is a Honeywell product I believe:
The timer seems revolutionary for not requiring a Neutral wire, yet requires no battery either.
Advantage: No more confusing wiring. Simple 7-step programming.
If old switch has 2 wires, the Aube changes to 2-wire application
If old switch is 3-way, the Aube changes to 3-wire application, the only major change is jumper on other 3-way switch
Timer replaces ordinary wall switch:
Timer replaces 3-way switch
Oct 06, 2010 | Aube Technologies Aube 7-Day Programmable...
Dryers Logo
157 people viewed this question
Top Dryers Experts
