Question about Dell 0JM629 Inspiron 1520 Keyboard
A key on my keyboard won't press down...what can i do to sort it out?
One Key, the Scandinavian o with a slash, is very slow after installing Windows 10
Are you talking about this ?. If so a trick to input it is to hold down the ALT key and press 149 on the numeric keypad. You can input all sorts of symbols, check out this list.
http://www.alt-codes.net/
May 01, 2016 | Microsoft New 200 Keyboard Wired Black Usb...
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
We put our Acer desktop to sleep last night and now the keyboard won't activate-no lights on function keys or anywhere else.
Have you tried disconnecting the power supply and battery for about a minute.Then reconect the battery and power and restart.Has worked for me
Oct 23, 2012 | Acer Power S285 PC Desktop
My keyboard won't light up on an ASIA G73J. I have tried the function keys and they won't work.
Did you hold down the [fn] key, in combination with the function keys? If not, you have to hold down the [fn] key in combination with pressing the function key's that are associated with the keyboard back-lighting (usually [F3] or [F4] on an ASUS G-series).
Aug 03, 2011 | ASUS G73JHA1 Notebook
What function do the keys along the top of the KG 0570 keyboard perform?
If you are talking about the special function keys, their function is determined by the program you are using. Normally, you won't use them. The exception is the F1 key which is universally used for "help."
Jun 02, 2011 | Acer Computers & Internet
Backslash-question mark and right shift keys not working
Welcome to FixYa!
i think there is some sort of obstruction , that's not letting the keyboard ? and shift key to press.
lift the keyboard and try to get it upside down.and hit it hard so any thing that's stuck should drop down . or see closely and check whats jamming the buttons i hope you get your answer
Do comment if it helps you in any manner
Apr 17, 2011 | Logitech EX100 967499-0403 Keyboard
DELL D510 KEYBOARD
Your alt or ctrl key is stuck. So the keyboard is running different shortcuts.
Jun 22, 2009 | Dell Latitude D510 Notebook
Keyboard Problem
Holding down the right-side SHIFT key has activated the "Sticky Keys" feature in Windows -- designed for physically-handicapped people who cannot press more than one key at a time.
Access CONTROL PANEL and disable this "Accessibility Option".
May 31, 2009 | Logitech Wireless Access Duo Optical...
Keyboard stuck in Fn mode
had the same prob on my laptop which doesn't have a seperate number pad so all I needed to do was to press "Num lock".
Apr 04, 2008 | Balance CN6555 Notebook
Dell 0JM629  Inspiron 1520 Keyboard  Logo
66 people viewed this question
Alun Cox
