Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
I have an I R Type 30 Model # 15 TE compressor that is not oiling the left cylinder. Is there an easy solution, such as: changing out the O-ring?
3 Suggested Answers
  • 1388 Answers
SOURCE: type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Posted on Nov 29, 2008
  • 214 Answers
SOURCE: Ingersoll rand compressor type 30
It sounds like the pressure switch is bad or out of adjustment. Typically the pressure switch is set at 175psi on a 2340. If the auxillary valve you are speaking of is on the pressure switch and is constantly blowing air from it you have a bad receiver tank check valve. Also if you are getting a lot of oil out the valve at the pressure switch you may have some oil control rings bad.
Posted on Feb 10, 2011
I own a Campbell Hausfeld model WL650800AJ compressor, the problem is that the compressor will not pressurize over about 85 psi..where would be the best place to start troubleshooting?..BTW, there is
The usual problem with oil-less type compressor is the Teflon compression ring and cylinder will fail causing the problem that you describe. Easy to check. With cover removed, turn the pump until the piston is all the way up. With good light, check the condition of the cylinder near the top. If the cylinder looks scratched, air is leaking past cylinder and ring and pressure will not build up enough to reach cut-out. If cylinder looks smooth, then problem is head valve reeds or head gaskets. Indication of bad reeds or head gasket blown, is extremely hot head during fill cycle. Good luck
Dec 07, 2014 | Campbell Hausfeld Air Tools & Compressors
My compressor started to spit oil from the cap what dos the solution?
Usually, oil at the fill plug indicates too much oil in the crankcase. Fill to top of notch cut into dipstick. The dipstick should have two orings that seal in oil and makes for firm fit into body of compressor. If oil and dipstick are ok, then suspect compressed air leaking past rings. Remove cylinder with head attached to check condition of cylinder / piston/ rings. Easy fix and low prices on parts. Go to www.toolpartsdirect.com Good luck
Apr 13, 2011 | Hitachi EC12 Portable Electric 2hp Air...
WHAT IS THE PROCEDURE TO REPLACE PISTON WITH NEW RINGS BACK INTO THE CYLINDER
Try putting a hose clamp around the rings and gently tighten it then with the piston in the cylinder tap the piston easy with a rubber mallet. Make sure you oil the cylinder rings and piston.
Mar 27, 2011 | Campbell Hausfeld 5-HP 80-Gallon Two Stage...
What is the spec on a ingersoll rand type 30 model 15
Hope this is sufficient information:-
Two-stage Type-30 replacement compressor pump for Ingersoll Rand Type 30 Reciprocating Air Compressors. U.S.A. Max. PSI: 175, HP: 15, Flywheel Diameter (in.): 18, Total Cylinders: 2, Bore Diameter (in.): 5 1/2 and 3, Stroke Length (in.): 4
Jan 25, 2011 | Garden
Wont build pressure past 60 psi
If you have oil-less type of compressor you may be leaking pressure past cylinder/piston ring or just air leak. Easy to check. Spray soapy water on all connections, first with pressure in tank and motor shut off, then once again with motor running/pumping. Repair as needed. If no leaks remove cover to motor and move piston to top of cylinder and examine condition. If you see scratches neer top of cylinder, then pressure is leaking past vinyl ring. If cylinder looks shiny and smooth and piston vinyl seal looks intact, suspect problem with reed valves or head gaskets. Parts are avilable at sears parts on the web. Good holidays expensive.
Dec 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Model 2545 compressor getting toomuch carbon deposit in side the cylinder
You can try switching to a full synthetic compressor oil to alleviate the problem.
Carbon is caused by the over heating of oil. Your problem is most likely an undersized compressor, or worn valves and piston rings.
Regardless of the problem synthetic compressor oil will help.
Hope that helps,
under_psi
May 16, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Why inter cooler is chocking frequently?
because oil is passing the rings check the piston rings also are you losing oil
Aug 23, 2009 | Ingersoll Rand - Rand Type - 30...
WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Nov 26, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5 Logo
190 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
