Question about HP DeskJet 5150 InkJet Printer
I used to have a pop up window that showed the ink levels for my HP deskjet 5150 printer, since getting a new computer I don't see that anymore. How can I get that back
    Sergeant:
  • 212 Answers
It's possible that with your new computer, when you plugged in your printer, Windows could have installed a driver for it automatically.
If that's the case, it would have only installed the driver, and not the utilities that HP puts on the disk. Find your HP Printer CD and install the software on it. Or download it from HP's site to install the utility.
Posted on Mar 11, 2011
How do I check ink levels on my HP deskjet D4160 Printer
When your printer was installed, it came with a CD with a complete software package for your printer to report (ink levels/diagnostics/etc) to the computer. If it was installed in Windows 7 (and below) it would be found at "Start" (button) > "HP" > Deskjet D4160 > Deskjet D4160. In Windows 8 look for HP. Once you've opened the application it will query the printer for its status. One of the icons will show the "Estimated Ink Levels".
If you can't find the software installed or the CD you can find it at HP's (US-English) support page for your D4160 is at the link below. Persons from other countries you can find their language at HP.com/support. There you can find everything you need.
Ink Jet Notes:
·Printers can be set to "economy" (default or individual job) to save ink if high quality is not an issue.
·Follow the user's manual or print using all cartridges at least monthly to insure the cartridge jets do not get fouled with dried up ink. Once fouled its toast. I've never been able to clean one.
·New printers come with minimal ink in the cartridges.
·"XL" (high volume) versions of your printers ink cartridge is cost effective if you print frequently.
In His Grace
Elton
HP Support
Mar 03, 2015 | HP Deskjet D4160 InkJet Photo Printer
Since upgrading to Windows 7 and having to relaod the driver for hp deskjet 5150 I can no longer get my ink levels, ability to clean or calibrate the printer, etc. What do I need to do to get these...
You need to download a patch from HP. Go tot he HP Print Software Patch When Upgrading Vista to Windows 7
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77751-1&cc=us&lc=en&dlc=en&product=304431&tmp_track_link=ot_search
This patch will fix known problems with the following features and functionality:
•HP Print Status
•Toolbox
•Ink Levels
•Solution Center
•HP Scan (All-in-One)
•Front panel scan button (All-in-One)
Trust this is helpful. Please vote. :)
Dec 15, 2010 | HP DeskJet 5150 InkJet Printer
Hii need to reset the hp deskjet 680c printer.i don`t know how to do this. thanks for you attention. regards.
h10032.www1.hp.com/ctg/Manual/c00256077.pdf -
Above is your user manual.
Turn off your HP DeskJet printer. Turn it back on and connect it to your computer using the USB cable.
To reset the INK Counter, see below.
Click open the "Start" menu on your computer. Click on "Control Panel," and double-click "Printer and Faxes."
Locate the icon of your HP DeskJet Printer along with its model number. Right-click this icon and click on "Properties" from the pop-up list.
Click the "Services" tab and select "Service This Device."
Select the "Estimated Ink Level" tab. Click the option "Reset Ink Level." The printer will then show a refreshed ink cartridge level for your printer.
To reset all settings and print test page. see below.
* Press and hold the Power button.
* While holding the Power button, press and release the Resume button four (4) times.
* Release the Power button. A self-test page will print.
Jun 17, 2010 | HP DeskJet 680c InkJet Printer
I cannot find how to access the ink level on my HP 5150. There is no "service" tab on my "printer preference" window.
let me tell u this means ur printer full feature driver is not installed in ur computer to install the driver u can try this link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=304431&lc=en&cc=us&dlc=en&lang=en&cc=us
and the other way u can check the accurate ink level in by printing a self test page
  1. Ensure the printer is turned on.
  2. Press and hold the Power button.
  3. While holding the Power button, press and release the Resume button four (4) times.
  4. Release the Power button. A self-test page will print.
Feb 23, 2010 | HP DeskJet 5150 InkJet Printer
Hp deskjet 5150 just replaced both inks...black
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 31, 2009 | HP DeskJet 5150 InkJet Printer
Not printing black anymore
The link level display doesn't always show the correct information. To begin, try to wet the part where the ink flows, with a damp paper towel or just a towel. Sometimes the ink just dry up. If that does not work, you probably need another black ink. If there was a problem with the printer itself you would had been notify by the computer, you know, like a pop up window.
Sep 01, 2009 | HP DeskJet F380 All-In-One Printer
Can't find ink levels for my HP Deskjet 5940
The installation disk for your printer has a setup wizard that monitors your ink levels in your printer. Go through the installation again as it will not hurt anything and you should find it on one of your pop up screens that it leads you to.
Jan 14, 2009 | HP Deskjet 5940 Photo InkJet Printer
Deskjet 5150 windows me?
hi john,
           just follow the below link, where u can download software for windows ME for ur deskjet 5150..
good luck
Jul 03, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
298 people viewed this question
Seeker5211
Seeker5211
