Question about 3M 9200IC Interactive Digital Wall Display 9200IC
Trouble lights 3 and 4 are on? - 3M 9200IC Interactive Digital Wall Display 9200IC
I have 2008 chevy hhr and recentlynIt takes 2-3 times to turn the key on before it will finally start then the other day the engine light came on. any solution?
There are well over 800 possible trouble codes that can turn on the engine light, so we don't waste time guessing trouble codes. Get the trouble codes read for free at any auto parts store. If you need help, post the codes here.
Check engine light on Part Ricks Free Auto Repair Advice
Aug 22, 2017 | Cars & Trucks
Why controller light flashes but wont work
Flashing lights on a controller are showing you a trouble code. To find out what the code means, count the blinking LEDs.
Here's a link to Pride's troubleshooting guide for the Jet 3:
http://www.pridemobility.com/includes/download.php?f=troubleshooting/INFINFB2045_Jet_3_Ultra_Troubleshooting.pdf
Feb 05, 2015 | Jet 3 Ultra Power Chair
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
Apr 04, 2014 | DSC Home Security
I have a 2004 grand am and it sounds like it is running on 3 cylinders instead of the four and the trac off light is on and service engine light
The first thing you would do is have the computer scanned for trouble codes. Then research the trouble codes online to proceed with troubleshooting the problem.
Sep 21, 2012 | 2004 Pontiac Grand Am
ABS light comes on... but no noticble degradation in operation etc.
Most likely a wheel speed sensor, hopefully... The only thing that will change when the ABS light is on is that the ABS will not function as long as the indicator is on. I hope this info helps.
When the airbag system is in functioning condition, the airbag warning light will remain on for about 7 seconds and go out when the ignition switch is set to ON .
If there is any malfunction, the airbag warning light will either stay on or off continuously. In such cases, perform on-board diagnostic in accordance with the specified procedure to determine trouble codes.
  1. Turn ignition switch ON (with engine OFF ).
85091723
  1. Connect DIAG. terminal to No.2 terminal of diagnosis connector located inside lower cover.
  2. Check in accordance with the trouble code indicated by the AIRBAG warning light, and record the trouble codes.
  3. Turn the ignition switch "OFF " and remove the DIAG. terminal from No.2 terminal of diagnosis connector.
85091724
HOW TO READ TROUBLE CODES
The ABS lamp flashes a code corresponding to the faulty parts.
The long segment (1.2 secs on) indicates a "ten", and the short segment (0.3 secs on) indicates a "one".
NOTE: This is the only information provided by the manufacturer for clearing diagnostic trouble codes.
97511505
CLEAR MEMORY
After eliminating problem as per trouble code, clear memory as follows:
Make sure ignition switch is ON (and engine off). Connect one DIAG. terminal (1) on diagnosis connector (2) terminal No.1.
where warning light is flashing, connect the other DIAG. terminal (3) on terminal No. 2 for at least three seconds . After memory is cleared, normal warning light flashing rate resumes. (Warning light flashes every 0.6 seconds (ON-OFF operation.) Memory cannot be cleared if any problem exists.
After clear memory and then DIAG. terminals (1) and (3), extract from diagnosis connector (2)
Jul 27, 2011 | 1999 Subaru Legacy
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
6=RF Jam Detected
8=PC5204 AC Failure
2=Loss of AC Power
Aug 09, 2010 | DSC Power Supervision Relay For Smoke And...
While riding the check engine lite comes on,causing a little flutter in it's running,then the lite goes off and engine runs smoothly,however, it happens again and again
Check for trouble codes to find out what is happening. To retrieve trouble codes,turn ignition to run for 3 seconds then off for 3 seconds. Repeat this. then turn ingition on and wait about 8 seconds. there will be a number of flashes (about 3 per second) from the check engine light then a 2 second pause then it will flash a code. There will be a 1 second pause between flashes for a digit more than the value of one and a 2 second pause between the first digit and the second digit. All trouble codes are two digits. After you get the trouble code, contact me and I can advise you what it is related to.
Nov 12, 2009 | 2001 Harley Davidson FXST Softail Standard
Red Light Engine
you have a trouble code turn key off and on 3 times to make dash lites go on then off and on the 3rd time leave the key on and watch the lite it should start to blink count the blinks and let me know be careful cause there will be paulses betwin some to make up your trouble code ie 2 3 eqals code 23
Sep 19, 2008 | 1995 Jeep Cherokee
Computers & Internet Logo
23 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
