Question about Brother SE-270D Computerized Sewing Machine
The wheel is completely stck and will not turn. I was sewing and everything was fine and then all of sudden this happened...i took apart and cleaned....can't figure it out.
  • 4 Answers
Check the top shaft bearings. Have similar problem on another computerized model. Top right bearing was completely stuck. Using Liquid Wrench to unfreeze it. Afterwards use sintered bearing oil like Tri-Flow to lubricate bearing.
Posted on Mar 27, 2011
I have a Singer 7466 and recently I developed an issue with the thread stripping and then breaking.
three possible reasons
old cotton will break or shred easily so get brand new cotton
next is eye size of the needle
a small eye with a heavy gauge cotton will not allow the cotton to pass easily
next is needle /hook timing
out of time allows the hook to pierce the needle thread and create the problem take it to a service centre for a check of the timing
Jan 11, 2017 | Singer 7466 Mechanical Sewing Machine
Problem with my bobbin case I'm sewing suddenly there clunking, my machine jams, bobbin case flipped 180. took apart, re-adjusted, put everything back and it worked fine, but it keeps happening. Help
Sounds like there are some parts that are worn or broken on your machine. A bobbin, when correctly inserted and latched, should not spin 180 degrees on its own.
Have you tried a brand new needle? Just wondering if it is bent and hitting below the needle plate.
Jul 28, 2016 | Sewing Machines
I have a vintage PFAFF 30 sewing machine. I was sewing and the needle suddenly stuck down and wouldn't come up even when I turned the wheel. I tried everything i could think of to fix it. But I...
I recently purchased a Pfaff 30 with the sane problem. Local repair shop took it apart cleaned and oiled it and it's as good as new he charged 50.00 fir the repairs
May 28, 2011 | PfaFF Sewing Machines
Error code 6 (thread in motor but there is none)
If you can turn the balance wheel by hand and the needle goes up and down it may be loose belts, if you can't turn the balance wheel by hand then there is definitely thread stuck somewhere in the raceway
Jun 24, 2010 | Brother CS6000i Computerized Sewing...
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Sewing machine stuck on reverse only
The same thing happened to me. I think this machine is just junk!
Feb 17, 2008 | Sewing Machines
Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Mar 10, 2007 | Euro-Pro Shark 80 - 7133
Brother SE-270D Computerized Sewing Machine Logo
131 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
