Question about Nokia GPS
I have a clarion NX700E multimedia which the GPS signal says it is connected in the settings, however it rarely ever connects to a satellite (The best i get is an orange dot rather than a green for a satellite connection). The device has been updated several times by the dealer due to other faults such as the bluetooth not working. Is this a software or hardware problem? btw the unit has been replaced once.
SOURCE: Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Posted on Nov 22, 2007
  • 1894 Answers
SOURCE: Connect PDA TO GPS
you can start using one you have paired them.
connect your pda to your systems port.
Posted on Sep 28, 2008
SOURCE: Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Posted on Oct 06, 2008
SOURCE: cannot connect to computer
Used a paper clip end and pressed the reset button for 15-20 seconds. No data was lost, but I was able to connect to my computer and continue with the updates, etc.
Posted on Jan 06, 2009
ajuhere81
  • 256 Answers
SOURCE: Acer Aspire 5720 'quick launch' buttons
it may be due the windows problem , virus in system or not proper driver installed . pls check for all this
Posted on Aug 12, 2009
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
Acquiring satellites
The problem might be that your GPS is not able to connect to the satellite.
I'll see what the problem might be.
Mar 15, 2008 | Garmin nuvi 350 GPS Receiver
TOMTOM GO LIVE 2050 problem with TOMTOM Server
Have you been able to get satellite connections (signals) when you're outdoors ? and not under/around tall buildings or overhanging obstructions.
Regularly get QuickGPSfix update (using TomTom HOME) to download the latest satellite positions (for the next 7 days), to enable your GPS to find the satellites quicker.
Jul 17, 2013 | Tomtom GO GPS
Why tomtom always say to me that my device is not connect
When the GPS device is not able to receive (more than 3 or 4) satellite signals, it will continue to search. This may take a while ... or if you're indoors or under cover of some (solid) obstructions, it may not happen. So, make sure you have clear views of the skies when you are trying to get satellite signals.
Consider regularly updating the GPSQuickFix file (by connecting your GPS using TomTom HOME) to download the positions of the satellites (over the next 7 days). It may help.
May 01, 2013 | Tomtom GO 720T TMC
Garmin 545s lost gps signal/reads gps error on satilitte page
Lost Satellite Reception - the unit has lost satellite signals. Check
antenna connections or try moving to a location with a clear view of
the sky.
Jan 11, 2012 | Garmin GPSMAP 545s GPS Receiver
Will not find city or locations
Hello.
Solution to the problem.
With the right piece of hardware and software, it ispossible to triangulate your location anywhere on earth using satellitenavigation. These gamin devices cansuccessfully guide you from one place to another, or they can simply use theconnection with the satellite to tell you your exact current location. Thelatter function requires you to know how to locate the GPS device using theoptions onscreen.
1 Purchase a GlobalPositioning System (satellite navigation) product. There are manymanufacturers, including TomTom, NavMan and Garmin.2 Turn on the GPS and leave itfor a minute or so as it establishes a connection between the device and thesatellite.
3 Navigate to the"Current Location" option in the "Tools" or"Settings" menu (the exact pathway to this option depends on whichGPS device you have). The satellite signal will now successfully locate yourGPS device.4 Type a ZIP code or placename once you have located your GPS device. The gamin can now successfully guide you to your finaldestinationThanks.
Sep 18, 2011 | Garmin nuvi 255W GPS Receiver
Standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Just says waiting for gps signal
Tom Tom needs comms with GPS satellites orbiting the earth.
Make sure you are outside your home so the GPS can find these signals. Initially it may take up to 5 minutes to make these connections. One the satnav knows where it is, all subsequent connections will be a lot quicker. :)
Some vehicles have windscreens with special coatings which prevent the satnav initialising with GPS satellites. If this is your problem, the only solution is to purchase an external antennae for your satnav. :(
Mar 08, 2009 | Tomtom One XL GPS Receiver
I am losing satelite connection frequently. Sometime for a few seconds and sometime for up to ten minutes
Hello jacke328,
In order to maintain satellite connection your GPS receiver needs a clear view of the sky. If you are operating the GPS in areas where the view of the sky is limited due to tall buildings, hills and mountains, or dense forest, your GPS is liable to lose signal from one or more satellites and this can impact the receiver's ability to determine your current location.
If you are operating the GPS inside your vehicle an external antenna may help significantly. The body of the vehicle can act as a shield, blocking the GPS's ability to receive satellite signals. This is why most manufacturers recommend installing GPS receivers on the dashboard with a clear view of the windshield as this maximizes the amount of visible sky. Installing an external antenna on the vehicle and connecting this to the GPS can help significantly, however.
Depending on the geography of where you are operating the GPS, you may have to live with an occasional loss of connectivity. With proper mounting you can minimize this, however.
Best Regards
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
GPS Logo
202 people viewed this question
Top Nokia GPS Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Nokia GPS Expert? Answer questions, earn points and help others
