Question about Canon CanoScan LiDE 30 Flatbed Scanner
Cannoscan Toolbox Vista
No scanner in toolbox Settings, I've installed toolbox and new driver for but so cannot scan. How do I get the toolbox to recognise it. Scanner shows on device manager and will respoond to test.
CANNOT INSTAL CANON n1240U SCANNER ON WINDOWS 7
Your scanner model is not supported on windows 7.
Jun 07, 2011 | Canon CanoScan N1240U Flatbed Scanner
I have canoscanlide 30 i canot install the toolbox to my pc windown vista whay can i do
two possibilities...
1. the toolbox software may need to be installed as administrator and in compatibility mode
2. it may not be installable if your pc is a 64 bit pc and your toolbox software is 32 bit... this is a common issue...
Dec 23, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Connot make a pdf scan. get a reply thet there not enough space. installed latest drivers. working with xp
Issue: ERROR: Insufficient space on target disk
Solution: Change where temporary files are saved (Toolbox)
Change where temporary files are saved (Toolbox) For an unknown reason, the computer is not allowing temporary data to be written to the general folder chosen by Toolbox at the time of install.
  1. From the CanoScan Toolbox, click the Settings button.
  2. At the bottom you will see a section that states, "Select Folder Where Temporary Files are Saved:".
    Click the Browse button.
  3. Browse to a folder, such as C:\Temp, and then click OK.
  4. Click OK again to exit the Settings window.
  5. Try scanning again.
Sep 13, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Can't calibrate the scan before scanning
I had the same problem when upgrading to mac os x. I was trying to scan directly from Photoshop but got the calibration message. I tried the two solutions given at the Canon website but they didn't work. I ended up downloading the Toolbox application to scan directly from there but the same message appeared. After installing the Toolbox application I unistalled the driver (11250) and reinstalled it. I opened Photoshop and tried scanning and the calibration window appeared only this time it didn't stop to give me the "Flim Adapter" warning. I must point that the scanner lid was open when this happend but I'm not sure that had anything to do with it.
So apparently it works if you have the Toolbox installed prior to installing the driver. The driver, Toolbox application and unistall driver can be found at Canon's website. Hope this helps.
Ciao!
Jun 02, 2009 | Canon CanoScan LiDE 500F Flatbed Scanner
Calibration cannot be performed Error
Ciao!
Aug 30, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Vista and the toolbox don't seem to work together
The Canon Flatbed LIDE 30 will not work under Vitsta. We're out of luck.
Aug 29, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
Your post for CanoScan LiDE 25
Hi there, yes I did everything per your instructions, Toolbox is installed and it still says, "release the lock switch, detach I/F cable and reconnect. Scanner driver will be closed" and then after clicking on that it says "Unable to open TWAIN source. Please check connection then restart toolbox" I have been to the Canon site and downloaded driver sites and it says everything is working. but when I go to scan it comes up with the boxes I said before. Quite lost at the moment? Thanks Maureen. PS I have unstalled and reinstalled
May 22, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 30 Flatbed Scanner Logo
193 people viewed this question
old marine
old marine
