Question about Refrigerators
Too cold in fresh food section - Refrigerators
    Sergeant:
    Champion:
  • 247 Answers
Lessen your thermostat setting.
Posted on Mar 11, 2011
My Model #gts22wcp fridge stopped getting cold. freeezer works great. Only blows cold air into fridge if freezer door is open.
Possibly a problem with the defrost system. If the cooling coils behind the freezer wall start to build up too much frost or snow, the air flow to the refrigerator section gets blocked first. So the freezer still works but the fresh food section starts to get warm . As the frost continues to build up, in time the freezer section will only get as cold as the fresh food section should. There are 3 main parts to the defrost system. You could have a burned out defrost heater, a bad defrost timer, or a bad defrost termination thermostat. The heater is located directly under the cooling coils in the freezer. The termination thermostat is a silver round disk clipped to the top of the same cooling coils, and the timer in located in the control panel in the fresh food section.
Apr 02, 2016 | GE Refrigerators
My refrigerator is not cooling on the refrigerator side
There are so many things that can make your fresh food side not cool. Usually, it is a frosted up evaporator, which is blocking the air flow of cold from coming from the freezer to the fresh food section. This can be caused by a bad defrost timer, a bad defrost thermostat, a bad defrost heater, or a bad control board. It could be a week compressor that is only strong enough to cool the freezer, the evaporator fan may be bad, which blows the cold air from the freezer to the fresh food section, the damper control going from the freezer to the fresh food section, can be stuck in the closed position, or in rare cases, the light in the fresh food section can be staying on, or even the condenser fan that is responsible for keeping the compressor and condenser from getting to hot, may be bad. This is usually behind the bottom of the fridge. You might also have a dirty condenser, which is the coil that is usually underneath the fridge. So you are most likely going to have to call for service.
Jan 29, 2015 | Refrigerators
Why is my kenmore freezer cold, but refrigerator not even when set at highest temp?
Hello Donna;
My name is peter. I am a retired field service refrigeration technician.
You have not provided your unit model number, which is located in your fresh food section on a label, on the side wall near the top.
You only have one cooling source, and that is your freezer. Your freezer feeds your fresh food section. This is through a direct air vent.
Reach into your fresh food section where the air vent from the freezer goes into the fresh food section. Do you feel cool air? Probably not.
So, either the air vent is frozen up with ice which you can clear with a hair dryer, or you have a automatic air vent motor/ sensor assembly that is bad.
Give me more information and I will help you.
Jan 21, 2015 | Kenmore Refrigerators
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
The Fresh Food Section dose not get cold even when it at the highest setting
I have the same issue and have not yet resolved. However, top left of the fresh food side has a plastic cover. It has two 1/4 screws. Behind this is a door that allows cold from freezer into fresh food. On mine this door is not functioning. If you open freezer and reach in you can push this door open (swings open into fridge side). I put a stick in there to keep fresh food from spoiling until I figure out the repair. Maybe the temp sensor.
Feb 17, 2011 | Refrigerators
The fan in the fridge freezes up and stops working about once a month.
While you getting the info, you said the motor in question is in the fresh food compartment, not the freezer.
If the fan motor is running properly (moving the air as it should) then it seems the fresh food section is running too cold.
The fresh food section should be in the range of 37 to 38 degrees, too warm for ice to build up. Could be a thermostat set too cold or going bad.
Jan 27, 2010 | Refrigerators
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
