Question about Sony Car Audio & Video
Is there a hole in the passenger footwell to run the lead from the battery to the amp in the boot?
    Scholar:
  • 71 Answers
Unless there was an amp previously installed on your vehicle, you will probably have to drill a hole through the firewall of the engine compartment yourself. Be sure you don't drill through any fluid lines though.
Posted on Mar 21, 2011
My 1995 mercedes Vito 113 just stopped running while driving along the road. I was accelerating and all of a sudden it stopped runnning, the dash lights all immediately came on.
run the fault codes
could be a broken timing belt or chain
could have blown the main power fuse next to the battery ( around 80 amps ) and that would have switched everything off
Sep 29, 2016 | Seat Cars & Trucks
Where is the battery located on a ferrari 458
if you can find the battery and know the correct procedure for attaching the jumper leads then there will be no problems
Dec 28, 2014 | Ferrari Cars & Trucks
Water leak passenger footwell
its the drain hole either side of the top of the firewall ,remove the plastic trim under the wiper arms and then clean the holes out ,also make sure that the AC drain pipe under the car passenger side is clear as well .LHD not sure where it is on a RHD vehicle but it will still have one
Dec 30, 2013 | Peugeot Cars & Trucks
Fiat scienco and water in car passenger side footwell
The sunroof drainage channels may be clogged.
Nov 07, 2017 | Fiat X1/9 Cars & Trucks
I have a rover75classic 54 it is leaking water when it rains on near side is it a useual fault
Had same problem. Lift up rear seat on drivers side and you will see a steel tube running from the wheel arch under the seat. Tube is about 2 inches wide. If this is rusted underneath then water is getting via the wheel arch open end of the tube. It runs into the rear foot well and forward into drivers footwell, also runs under rear seats and into the boot! I removed the rear drivers side wheel, pulled away the plastic wheel arch lining then sealed the hole where the wiring leads through this pipe. Covered it with plastic flashing replaced the wheel arch lining. Took 30 mins to repair, took a week to dry the carpet, rear seats and boot carpet.
Jan 20, 2013 | 2000 Rover 75
Locating fuse boxes for 1996 grand cherokee
One under the hood another under the dash on drivers side.
Aug 29, 2012 | 1996 Jeep Grand Cherokee
Leaking inside the car everytime it rains
There is probably a drainage hole underneath the cowling under your windshield wipers. They're supposed to allow the water to drain out into the wheel well. See if the passengers side is plugged up. Collected water has to go somewhere and it will always find a place.
Mar 02, 2010 | 2000 Ford Focus
Water in the rear passenger footwell
Not unless it was blowing like stink. Was a rear window left open? Water could get in around the rear window and find it's way there. Have someone spray the car with a hose while you're in it or ride back there through a car wash. Have a friend help and you buy the treat.
Jun 17, 2009 | 2000 Mercedes-Benz C-Class
Water leak ns rear footwell
I had the same problem on my 2003 Audi.The guy who fixed it told me that he sees alot of Passats with this problem.
The drainage holes underneath the battery get blocked by leaves etc. leading to a build up of water.This then leaks through the heating ducts into the rear footwell.
In my case it wiped out the electronics for the alarm and central locking(£200 for a new one).
Hope this helps you.
Jun 07, 2009 | 2001 Volkswagen Passat
Warter getting inside car golf 2003
sunroof guttering blocked try getting an airline around the sunroof when open and blowing down there ??
Nov 12, 2008 | 2003 Volkswagen Golf
Car Audio & Video Logo
19 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
