Question about Garden
I would like to know how to phone ebay. i baught a powerhouse log splitter on line and i am haveing problems with it and i lost my paper work. i have went to ebay with and got no results. thank you in advance. samcohen64@yahoo.com.
    Sergeant:
    Champion:
  • 250 Answers
Here is how to get intouch with ebay
866-877-3229
Posted on Mar 11, 2011
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
Masport log splitter how do you rewire a 7tonne pressure log splitter
Make sure the device is unplugged from the 240 VAC power source.
Connect the 240 VAC line and neutral wires to the momentary switch. Examine the motor wires to determine line and neutral.
This log splitter is equipped with a control system that requires to be operated by both hands of the user - Left hand controls the
hydraulic control lever while right hand controls the pushbutton
switch. The log splitter will freeze upon absence of either hand. Only
after both hands release the controls, the log pusher starts to return
backward to the starting position.
http://www.masport.co.nz/common/download/556964/
Hope this helped.
Apr 20, 2014 | Tools & Hardware - Others
Bt hub 2.0, the internet light is red, but the telephone line works, although it's very noisy/crackly. have changed the micro filters but still cannot connect to the internet.
It sounds like you have a fault on your phone line which is affecting the performance of your broadband.
As long as you haven't added any more phones to your house without a splitter, then I would go with the problem being your phone line.
You might want to give BT Broadband (assuming you have BT broadband with the BT Hub) on 0800 111 4567 they will be able to advise you further, failing that, you may need to log a call with BT about the phone line itself, which is just 151 from the line that you are having problems with. It is always best to phone from the line that you are having problems with, so they can hear that there are problems with the line.
Hope that this information helps! :)
Nov 08, 2010 | Computers & Internet
Parts are missing for The Impex Powerhouse
Wore out and the maufacturer cannot replace a tech rod unit for an impex TR-2 home gym.Need complete unit of 2-50lb,2-25lb,4-10lb,2-5lb rods on a plastic base.Can anyone help?
Feb 06, 2010 | Exercise & Fitness
Need two phones connected to the one jack in our office.
Have you purchased an incorrect splitter. You may have one for 2 lines rather than one used to split one line. Radio Shack has the proper one.
Aug 19, 2009 | Lands Phones
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Both lines ring for one call
the splitter is on the one phone line through the single phone jack so it is logical that that is where the problem is
if you have 2 phone lines( 2 lines in from the service provider connection point on the building then there is no need for a splitter as in effect you have two phones
a machine cannot distinguish which phone to work from the one inlet line so it rings all phones connected
a splitter is only used when you run a phone and another unit such as a computer off the same line and not as how you have it set up
Apr 16, 2017 | Panasonic Lands Phones
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
