Our x-box has three red lights around the circle and one green one in the middle and won't show the picture on the screen when we turn it on. We downloaded a couple of demos and one movie from Netflix recently. We wanted to go and take off some things but now it is not even turning on. IS it because the hard drive is too jammed??? Help what can we do?
ALL YOU GUYS GOT TO DO IS CALL MS AND THEY WILL FIX IT FOR FREE WEATHER ITS UNDER WARRANTY OR NOT TRUST ME A FIX ELECTRONICS FOR A LIVING
THE TOWEL TRICK SHOULD NOT BE USED.
THIS SHOULD LEAD TO THE XBOX 360 GOIN ON FIRE!.
IF U SHOULD GET THE 3 RED RINGS AND ONE GREEN LIGHT.
FOLLOW THE 3 STEPS.
1. CHECK THE AC POWER BOX DOES IT HAVE GREEN LIGHT
IF IT DOES THIS CHOULD JUST MEAN THE XBOX IS OVER HEATING. TURN OF AND LEAVE TO COOL FOR AROUND 1 HR
2. IF THE AC POWER BOX IS ALSO SHOWING THE RED LIGHT TURN OF AND POWER OUT LET AND REMOVE THE AC PIOWER PULG FROM THE WALL AND THE OTHER RED FROM THE XBOX 360. REPLUG THEM BACK IN AND RELOAD THE XBOX 360.
3. SWITCH OFF THE XBOX 360 AND SWITCH OF THE POWER ALL THE MAIN SWITCH. CHECK THE AC POWER BOX ITS IT HOT THIS COULD BE OVER HEATING. MAKE SURE NOTHING BLOCKIG TO AC POWER BOX AS THERE IS A COOLING FAN IN THERE TO KEEP IT COOL.
MAKE SURE THE POWER CORD PUSH IN RIGHT IN THE XBOX 360.
IF STILL DOES THIS THEN UR XBOX 360 NEEDS TO GO FOR REPAIR.
GO TO WWW.XBOX.COM
AND CLICK TO THE SURPPORT LINK FROM THERE EMAIL THEM OR PHONE THEM THE NUMBER ON THE WEB SITE TO BOOK A REPAIR.
PLEASE DO NOT USE THE TOWEL TRICK. THANKS
READ THIS FIRST!
If you have the 3 red lights or any other common Xbox 360 problems suh as the
You can learn to fix these problems for free.
There are loads of these guides out there that all claim to fix the
problem however you should read the article below that will shed some
real light on whether or not you can repair your Xbox 360 yourself!
Make sure you read the article first to avoid being scammed!
FREE ARTICLE REVEALS THE TRUTH ABOUT XBOX 360 REPAIR GUIDES HERE!
Caused by overheating!
Do the towel trick
1. unhook everything execpt the power cable
2. turn on and wrap in 3 towels and let sit for 20 to 30 min
3. unwrap all towels (xbox should be really really hot)
4. turn off console and let it cool for 15 to 20 min
5. turn on console and play for about another week or two maybe longer.
this happened to my xbox and i did the trick and it has worked for 2 months but note this is only a temporary fix.
How can i fix this ring of death it will not let me play the game
SOURCE: 3 red lights and one green one in the middle HELP
Put the console off ..... wait 10 seconds and then try again
There are repair guides out there that will fix it - but you had better find the right one for the job - here's a website that will help with that:
www.BestXBOX360RepairGuides.info
Good Luck!
2 red lights
1 red light sometimes 3
I have the 3 red lights and E74
power brick is RED!
2 red lights
3 rings of death? on x box 360 HELP!!
3 red lights come on and stay on also the green light stays on in the middle. Also i dont get any picture at all
i turn on my xbox360 and then it shows the three red lights flashing
3 red lights is the GPU!
Nearly all of these problems are caused by overheating and you can fix them yourself.
I used the blog below to fix mine and it took about 40 mins:
http://xbox3603redlights.wordpress.com/
3 ring of red lights
I dont know what to do, its not overheating. I left it alone for 24 hours and it still dosent work. it has 3 red lights and the green one in the middle I think it has somthing to do with the hard drive
1 red light
it has happened to my xbox twice since i have had it. I got it for christmas last year. try turning it vertical, mine started when i had it on its side. it works really well
1 red light
it is happened to me alot also. Had 1 red light now has gone into 3 red flashing red lights with no error message.
red lights on!
3 red lights
red lights on
2 red lights
2 red lights
3 red lights
just got this
i played a dvd and now when i turn on my x box i get three red lights and the middle is green cannot play any of my games
3 red lights flashing!
1 red light on all the time!
3 red
me as well
i was playing halo 3 and i got like 15 achievements and onw it isn't even turning on
3 red rings but the middl is green nothing on the screen it comes on sometimes.
Here have best solution of this problem check this out:http://solvexbox360.blogspot.com/
Solution Link . . . www.MicrosoftXbox360Console.com
When someone say that his/her Xbox is having 3 red lightsproblem, It means it needs to be repaired. If you are using Cooler thanit is not a cure but a prevention. You could have used cooler beforeacutally having the problem just to prevent your Xbox. But now you willhave to either get it repaired from Microsoft (in case your Xbox'swarranty is not expired, but one thing to note is that you will have towait for at least 3-4 weeks to get back your Xbox) or you can Fix yourXbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
