Question about Canon imagePROGRAF IPF710 Printer
Canon IPF700 error message E161-403E, how do I fixt this?
    President:
  • 287 Answers
Welcome to FixYa
Error message E161-403E is a print head over heat indication.
Turn off and turn on the printer see what will happen. If error still exist then you have to replace the print head.
Before you have to update the firmware to the latest version.
Try to access the service mode in order to update the firmware
Error will be removed.
If you have already tried above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks
Posted on Mar 11, 2011
What is Canon ipf700 error code hardware error 03130031-2f1f
I have the same error. I have been told that I need to replace the purge unit. Can I do it myself and save big $.
Jun 23, 2014 | Canon iPF700 InkJet Printer
I have a canon ipf700 and power went off and now the machine is coming up with an error message of E161-403E. any help will be great
Hold down the roll/media button and the info button while turning on. Wait about 10 seconds and release roll/info buttons. You should get an "S" in the upper right corner; this puts you in service mode.
Push menu then scroll down to maintenance then right arrow to head replacement. Then get out of service mode turn off.
E161 403E means abnormal print head temperature. The print head needs to be replaced. Boot printer into service mode, and from the menu select head replacement.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 03, 2011 | Canon iPF700 InkJet Printer
WE HAVE A IPF 700 AND IT PRINTS FOR 10 SECOND AND THEN COMES UT WITH HARDWARE ERROR 03130031-2726 CAN YOU HELP
when i start my Canon ipf700 it comes upwith error message hardware error 03130031-2618
Jul 01, 2010 | Canon iPF700 InkJet Printer
Error 3130031 Canon ipf700
we need to post us the 4 last digits of this error code.
The code you are posting is the same for lot of error codes
Dec 10, 2009 | Canon iPF700 InkJet Printer
We keep getting an error 03800500-2f2f on our 8000s and 9000s
Maybe you can try upgrading your printer driver. That helps at times.
Aug 17, 2009 | Canon iPF700 InkJet Printer
As to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Mar 13, 2009 | Canon iPF700 InkJet Printer
Disabling Ink level Detection Canon iPF700
you can disable it only if an error occures at the first in filling, with the latest firmware installed (ver 1.37) if the machine will starts normally then you can't disable it.
Mar 11, 2009 | Canon iPF700 InkJet Printer
Clean printer head for iPF700 instead of replacing
If you have blocked nozzles unfortunatelly you have to replace the print head.
What about the nozzle check pattern?
Jan 28, 2009 | Canon iPF700 InkJet Printer
We have a Canon iPF700 plotter. Keeps flashing message about print heads needing cleaning which is not resolved by pressing cleaning button. Probably needs a service. Number of good engineer in our area...
First print a nozzlle check pattern. Check all colors. If the problem is in any other color than cyan then you can fix this issue. If not you'll have to replace the head with a new one.
Try to update the firmware also to version 1.32 (for iPF700) and 1.35 (for iPF710) and check the result.
Sep 10, 2008 | Canon imagePROGRAF IPF710 Printer
Canon imagePROGRAF IPF710 Printer Logo
8,222 people viewed this question
old marine
old marine
