Question about Carrier 38CKC036 Air Conditioner
Not working tha fan motor and compressor motor
    Genius:
  • Carrier Master
  • 1,033 Answers
Hello, the first thing is check if you are getting voltage at the contactor coil contacts on the outside unit, you should be getting 240 volts, If not most likely a breaker is tripped. Next check if you are getting 24volts at the contactor coil, if not either there is a problem with the thermostat or the low volatge wiring. if you are getting voltage but the contactor does not energize the coil on the conatctor is bad and must be replaced.
Posted on Mar 11, 2011
  • Robert Mar 11, 2011
    If the contactor checks out good, than most likely the capacitor is the problem and must be replaced.
How do I reconnect the capacitor?
Not easy to explain. The capacitor is split, it has two values, or like two capacitors connected internally with a center tap between them. Two capacitance values, maybe 5uf and 20uf, the lower value for the fan motor and the higher for the compressor, with terminals C-common, F-fan, M-compressor.
Capacitor terminal C is the center tap and that takes 3 connections, line (power) - fan line common to capacitor, and Compressor line common to capacitor. Notice the fan and compressor have a power line not common to capacitor, just power line.
Capacitor terminal F has one wire connecting to Fan terminal C, fan may have three or four terminal writes, two for power with one power being common to capacitor connection and the other power alone, two power connection wire leads. Fan motor third line is capacitor, connects to the capacitor alone. Four wire configuration fan motor is not likely your needs. Omit or ask again for further explanation.
Compressor is similar to fan, only with a capacitance value higher than for tha fan motor. Two power leads, one straight power, the other power lead connects to the capacitor power. The third compressor lead connects alone to the capacitor.
The with is to draw a diagram and level the colors of each lead and terminal lavels too. The motors nameplate may indicate wire color code, the a-c nameplate wiring diagram may be present in the control wron wiring compartment, the goal is to find clues or to trace each wire and verify what they connect or do, take notes on your drawing.
Basically the motor has three terminals, L1 - L2 - C, or C- S-R (Common, Start,Run)
Jul 14, 2015 | Maytag Heating & Cooling
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
Motor hums but won't kick in
Hi simpsonruth1..
In the back of the compressor motor you will see a fan, remove the plastic cover to get to it..
Once you have the plastic cover removed and the fan exposed, plug the compressor in and spin the fan with your fingers...be quick as the fan could cut your fingers if you do not get them out of the way..
If the compressor starts working, then the start capacitor is bad on the compressor...if it does not run then you have motor troubles, either replace the motor or get it rewound.
Please take time to rate me
Sep 06, 2011 | Paasche 1/8 HP Diaphragm Compressor
Need capacitor wiring diagram
No model number gotta shoot from the hip on this one:
The cap has 3 sections: Herm for compressor, F for fan, and C for common.
The common section of the cap gets a hot wire off the power cord, a wire from compressor marked C on compressor and a white common wire from the fan gets connected to C on that cap. These wires are almost always white in color on American OEM. The fan has a small brown wire that connects to F on tha cap. The compressor has a wire marked S on it make a note of that color wire and connect it to the section on the cap called HERM. Herm stands for hermedtically sealed compressor. So both your commons and a hot wire go to C. You need one small brown wire which goes to F from the fan. One wire marked S on the compressor goes to Herm for compressor starting. S stands for start winding.
Lets look at typical American fan motor wires: The fan has a black wire for high speed a blue wire for medium and a red wire for low. It has white wire for common, and a brown wire for capacitor. Connect your common fan wire to common and the brown wire to F.
With that cap properly connected basically all you would need to do to make it run is connect a fan speed, the compressor wire marked R for RUN, and and the other power wire.
Jul 20, 2011 | Fedders AEY08F2FCOM Wall/Window Air...
Why do i have to press the reset botton to get the ice to fall, on my Samsung RS2530BWP refrigerator? Also the side panels only on the freezer side are HOT to the touch and im worried it might become a...
Verify that the compressor fan is working. The fan is located behind the unit at the bottom. You need to remove tha back panel and observe that the fan is working while the compressor is running.
Mar 19, 2011 | Samsung RS2530BWP (25 cu ft) Side by Side...
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
How do I find a burning smell coming from my refrigerator? The freezer part is not staying cold. The compressor is very hot. I think that is what I smell burning. The fan next to compressor is moving very...
The slow fan could be the problem. The compressor is over heated and not working properly. Let it stay off long enough to cool down and put a fan to try temporarily and be sure tha is the only issue. It may have cooked the compressor.
Eric
Apr 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
Fan motor will not come on
That thing connected to the capacitor is a booster for the compressor .But if the outside fan doesn't work , the compressor will shutt off on overload because the high pressure in the condenser coil.
First try to replace the capacitor in the condensing unit (it's the only one that works for the compressor and the fan motor) ,but if the fan doesn't start, you need to replace the fan motor.
Sep 14, 2009 | Ruud UBHC Air Conditioner
Both the freezer and the refrigerator are increasingly getting warmer despite turning the temperature controls up I also haven't heard the compressor coming on in the past couple of days
Is tha fan running? If not then the compressor would go off on overload. If the fan is running and the compressor is then it could ba either a bad compressor or just a relay and overload.
Jul 17, 2009 | Refrigerators
True TDD-1 beer kegerator condensor fan not running
cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Oct 15, 2008 | Refrigerators
Carrier 38CKC036 Air Conditioner Logo
62 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
