Question about Dell Computers & Internet
Can i install a windows xp using a flash drive.
  • 126 Answers
Some computers let you check your BIOS settings (normally entered by restarting the PC and pressing delete or F11 while the PC boots) and look in boot options and see if USB device is there (it will have to be enabled to work) you also have to format the memory stick into a boot device
Im sorry I cant help you more without more details
Posted on Mar 11, 2011
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
So So Happy USB flash drive won't install onto windows xp
Format the flash drive without using the executable installation program on the flash drive.
Insert new flash drive, do not let anything auto-run. View the drive in the file explorer. Right click on the drive and choose Format in XP to let XP do a full format (not a quick format) of the drive. This will ensure that the drive works on XP... it will then also be accessible on a newer system.
XP may also not be able to work with flash drives over 32GB, or will only give you access to the first 16 or 32GB.
Sep 05, 2017 | Computers & Internet
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
How to install windows xp in msi k8mm-v motherboard?
Hi dharmen_shah,
I see that you need to install Windows XP on you Dekstop with an MSI Motherboard k8mm-V.
I have another desktop using the same Motherboard, there are 3 options installing Windows XP on the machine.
  1. Using an IDE Optical Drive
  2. Using a SATA Optical Drive "not a common installation process on this motherboard" since you will need to install the SATA rivers first to be able to use your SATA ODD
  3. Using a USB Flash Drive
See steps below for each installation type.
*Using an IDE Optical Drive*
  • If you have your Windows XP CD insert it on the Disc Drive restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • Once in the Boot Menu screen select your Optical Drive, it may say dvd/cd or ODD, select this and press enter. Note: windows may restart during the installation if it says press any key to boot to cd do not press anything anymore leave it will do everything on it's own unless prompted for any user information like a computer name date and time.
  • You will see on the screen Boot to cd: then it will show "press any key to boot to cd" press Enter or any key this will boot from your cd Windows XP.
  • Then you will see inspecting your hardware for configuration, once it boots to your Windows XP cd you will see a blue screen Loading up drivers and stuff for the installation of Windows XP.
  • Next will be the installation of Windows XP itself, just follow the prompt it is very easy to follow and it will give you all the details and what buttons to click on.
  • Note: Select Quick Format (NTFS) this will be faster reformatting your Hard Drive before installation.
*Using SATA Optical Disc Drive*
  • You will need a 1.4 floppy disc to be able to do this.
  • If you have a 1.4 Floppy Drive you will also need to download the SATA driver from the MSI website.
  • Let us disregard this option since I believe you do no have a 1.4 Floppy Disc Drive and no one uses that or has a 1.4 Floppy Drive anymore on their machines.
*Using a USB Flash Drive*
  • To be able to use a USB Flash Drive for the installation of Windows XP your USB Flash Drive should at least be 1GB or 2GB, 1GB will be enough since windows XP only uses at least 7++gb of disc space for the installer size.
  • Using you USB Flash Drive you will need to copy the whole contents of your Windows XP Cd into your USB Flash Drive, don't worry this will be bootable just make sure that you copy everything from the disc into the USB Flash Drive.
  • Once you have copied Windows XP on your USB Flash Drive insert it to one of your USB ports on the machine then restart the computer.
  • Restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • This will be the same as using your Windows XP cd but instead you will need to select USB in the Boot Menu then press enter. on the installation steps it will be the same as installing using a disc.
  • Windows may restart during the installation and using a USB Flash Drive will be different at this point because it will boot directly to the USB, Once it restarts and may repeat the installation all over, to prevent this as soon as the system begins to restart from the installation go and keep on tapping "Delete" once it restarts this will bring you to the BIOS screen press F9 to set it to defaults then press F10 to save and exit this will restart again.
  • Once it restarts after setting the BIOS to defaults let the system boot on its own it will then show you a screen asking what windows to install the first thing highlighted will be the installation that was halted earlier just press enter then it will show you the windows installation page and will continue on it's own.
This is based on my own experience since I have an older Desktop that has the same Motherboard, I hope that I have given you all the options possible to installing your windows XP on your Motherboard k8mm-v.
Have a nice day,
mvincentc
Feb 02, 2011 | MSI K8MM-V Motherboard
Wont let me boot windows xp off flash drive
Hi manbrand62,
I see that you are trying to boot to your Flash Drive for the installation of Windows XP, try steps below.
  • As soon as you start your computer keep on tapping F12 or F11 to boot to the Boot Menu, I'm just not sure if it's F12 or F11 on a dell but one of the 2 options will bring you to the Boot Menu page that is where you can select your USB flash drive to install windows from the USB.
  • Note: Installing from a Flash Drive will be different from using a CD, windows may restart during the installation and since you are going to be using a Flash Drive you will need to get to the BIOS screen once the system restarts then set it to default then save and exit saving settings.
  • This will restart the system and continue the installation process for Windows XP.
I hope that this will help you installing Windows XP using you Flash Drive on you machine.
Have a nice day,
mvincentc
Jan 12, 2011 | Dell Microsoft Windows XP Home Edition
I instol windows xp by pan drive but it stop working installing time driver.com
Check on this link on how to Install Windows XP using USB flash drive. Also try using a different flash drive or if you trying to install XP onto a Netbook, you can also using a USB DVD drive and boot to the external drive.
Jul 07, 2010 | HP Computers & Internet
How can i install windows xp in to my toshiba satellite using a usb cd drive?
you can copy the contents of the windows XP installation disc to the USB drive. A 1gb flash drive should be sufficient.
Apr 11, 2010 | Toshiba Satellite 5005-S504 Notebook
I have a aspire 5515 acer with Vista Basic and i want to install Xp Pro. When i try to install Xp pro it starts and the comes back that it is quiting the installion because it will damage something. How do...
There's no single way to install Windows XP. As there is no CD / DVD drive, you have two main choices:
1. Purchase an external CD / DVD drive. Plug it into a USB port on the Aspire, and then access the BIOS, Make sure the CD drive is first, and insert your Windows XP disc. You should now be able to install it normally.
2. Use a bootable Flash drive. This method will be far more difficult, and requires a moderate amount of experience with computers. First you will need to install QEMU on another computer. Create a hard drive the same size or smaller than the one in the Acer. Install Windows XP to it using QEMU. Copy the hard drive image onto a USB Flash drive. Now install some version of Linux on it, such as Puppy Linux or Damn Small Linux. Howtos are available in the Related Links section below. Boot from the Flash drive, and access a command line. Find your hard drive in the /dev folder (probably sda or hda). Now issue the following command
dd if=image.img of=/dev/hda
This will make an exact copy of the hard drive image to the hard drive in the Acer. Waituntil the command is completely done. Now turn off the computer and unplug the flash drive. When you power it back on, it should boot into Windows.
Jun 13, 2009 | Computers & Internet
Win 98 does not permit flash disk
sir u have to install drivers of flash drive  in win98 (the cd which u got with flash drive )coz xp is plug&play so their is no need to install drivers in xp try it good luck
Oct 22, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
