SOURCE: replacement clips on strap for graco mirage pushchair
I solved this problem by e-mailing graco and asking for assistance. and one of their advisors replied. I just sent them the model number and they are now sending out the replacement part.
SOURCE: maclaren quest pushchair.
Ok, I will try to do this step by step.
1. Place flat screw driver under hub cap and pry off (these we will reuse later).
2. Using diagonal pliers, cut star locks from axle, you should have received new one from Maclaren when you got the wheels, if not you will need to get those.
3.Repeat this process for each wheel.
4. Take off the old wheels and put the new ones on. Put on the new star locks (I use a small hammer), put the hub caps back on and viola, new Mac wheels.
SOURCE: can you replace Maclaren Triumph rear pushchair
Not 100% on this, but I would say NO! The wheels of the Techno are somewhat larger, and therefore I am pretty sure that they would not fit.
I hope that helped!
SOURCE: broken luna harness
if you contact mamas and papas they will be able to order it as a spare part.
