Question about Epson PowerLite® 83c LCD Projector
Temp gauge is flashing red i have cleaned the filter what else can i do
    Brigadier General:
  • 8,909 Answers
I would check the fans are all running freely and there is plenty of air moving around.
Posted on Mar 11, 2011
Epson 1925W projector has a brand new bulb but the lamp light flashes red. Power light is solid green and Temp is off
Reset the Lamp Hours, see if that helps. Also clean the filter and reset filter hours too
Nov 08, 2016 | Epson 1925W Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
2004 pacifica won't stay running. temp gauges are erratic. No code on PCM
The PCM on a 2004 Ford Mustang is a combined control unit, consisting of the engine control unit (also known as an ECU) and the transmission control unit.------------------------------------------------------------------------------------------
Launch X431 Master
Mar 07, 2013 | Chrysler Pacifica Cars & Trucks
Red Light flashing
it may be because of the problems as u described air filters and fan .but try first with the filter,u can find it at amazone or flipkart
May 03, 2017 | Epson Computers & Internet
The projector turned itself off after couple hours of use and the Temp. red light came on. Power Light turned red instead of orange as usual. After 3hrs I turned it back on, cleaned the dust off the fan...
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Jan 03, 2011 | Panasonic PT-LB50U Multimedia Projector
The red light on the temp gauge is flashing. The temp gauge itself shows temp to be normal. Any thoughts?
Possible that there is circuit error or the posistor reading is giving erros to the circuit to trigger the LED. If the guage is correct then there is no cause for alarm but to concur and find the solution. so check using a thermometer and confirm which is right. if so the circuit must be checked.
Sep 29, 2010 | 1999 Porsche 911 Carrera
Flashing Temp indicator light, after 5 min on a cool morning
Its a Low Coolant indication. Fill the reservoir to at least the MIN level.
Jun 02, 2009 | 2002 Volkswagen Cabrio
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Epson PowerLite® 83c LCD Projector Logo
284 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
