Question about Ovens
What size fuse would go in the plug for a halogen oven
  • 417 Answers
3 amp if its under 720 watts or 13 amp if its more than 720watts
Posted on Mar 11, 2011
Advantium--removing lower halogen cover
you need a torx/star screwdriver
Dec 31, 2013 | GE Ovens
Where is the thermal fuse located on an electric whirlpool in cabinet oven?
hello,
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks,
    Oct 09, 2010 | Whirlpool RBS305PD Electric Single Oven
    I have an elgento e452 halogen oven, need cooking instructions.
    need to replace fan on my elgento e452 halogen cooker
    Aug 28, 2010 | Ovens
    Is there something special about the halogen bulb used in an oven?
    USED ON OLDER OVENS WITH THE GRILLS.. MENT TO BE FASTER AND MORE RELIABLE...
    Mar 08, 2010 | KitchenAid KEBC206 Electric Double Oven
    We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
    Frozen food should be defrosted before cooking in halogen ovens.
    Halogen ovens use only radiant heat and will not cook the centre of frozen food.
    Jan 21, 2010 | Ovens
    Timer clock is not illuminated and oven will not work
    This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
    Feb 03, 2009 | Blodgett Ovens
    Halogen ring not working
    Hi .
    It sounds like the temp control is faulty.
    Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
    Sometimes you can see if the element has gone, .
    If you need any further help, let me know.Good luck.
    Nov 23, 2008 | Ovens
    How to replace lower halogen light assembly, also, replacing turntable shaft
    item 1474 is the turntable shaft and is GE # WB02X10624
    You should be able to remove item 1476 and lift out the shaft to replace it..then reinstall item 1476 to lock it in place, Hope this helps ...
    Sep 12, 2008 | GE SCA2001FSS Advantium Electric Single...
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
