Question about Ovens
I have a Diplomat 600 fan assisted oven. When switched on, the fan can be heard running, but the oven does not heat at all. Any ideas please? Is this likely to be expensive to rectify?
  • Ovens Master
  • 3,463 Answers
Hi.
It is going to be a faulty oven element.
Remove the cover at the rear of the oven compartment, and see if there is a round heater element there, if there is, then it will be the element that needs to be replaced.
If no element there, then it will be either the top element of the oven , or rhe base element which is not visible, that is faulty.
If there is base element, then it can only be accessed from outside of the main oven by removing the outer panels, and is located at the bottom of the main oven.
Hope this helps.
Posted on Mar 11, 2011
I have a diplomat oven - i turned it on this afternoon and whilst the fan revolves there is no heat coming from it! i tried the grill and this works fine and heats up! what could the problem be pls??
It sounds like the oven element is blown and needs replacing. If the oven fan and the indicator light are coming on it will be the element or possibly a burnt off wire at the oven element terminals.
Mar 12, 2011 | Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Oven that refuses to oven
what were you doing the last time it worked baking broiling self clean if the clock isn't on turn the breaker off for 5 seconds then on reply to me with make and model number from the serial plate on the door if that doesn't fix it but don't rate me till we are done
Jan 09, 2008 | Ovens
Ovens Logo
682 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
