Ip address i got a compact desktop to work on it had windows xp and them windows vita then dumped again and put windows xp back on the ip address will not release or renew i get a error in the prom command. have any idea how to get the ip address to release so this computer can got back online? Amy
  • 3 more comments
  • amyjo_73 Jul 31, 2008
    the ones that come up is subnet mask.and a privet ip address i have checked ether and everything if okay there all i can think of that who ever put windows vita and conneted to the net didn't release the ip be for dumping or the saved the partions and now it won't release the ip address
    the LAN settings are set to auto find with no proxy this was conneted though no router at this time now if i have a lap top can i pull the ip addresses off of that one and put them in manualy if so how and where would i go to do that
    it conneted directly to the fiber optic ether cable
  • Coss May 11, 2010
    What is the address it comes up with?
  • 261 Answers
You can try this site http://www.ip-details.com/ for getting the ip-address.
Posted on Sep 25, 2009
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Then you need to go into your control panel, to your network . LAN settings, and set the address in there.
If your router is set up for DCHP, telling your computer to automatically aquire an IP address will work.
That's one reason I asked what the IP is. If you are coming up with a 192.168.xxx.xxx your router is issuing the ip address.
If it's coming up with a specific address, it is set in the LAN setting. But you said you just rebuild the computer, that's where it doesn't make sense.
So I might need more information at this point. Check those setting first, and let me know what you find.
Posted on Jul 31, 2008
  • Coss Jul 31, 2008
    You said it's not connected to a router.
    What is it connected to?
    If it is set to automartically aquire, it is getting the address from something.
    Other wise it would come up with an address of 127.0.0.x (local host address).
    So there is something else in your system/network that is doing DHCP
  • Coss Aug 01, 2008
    Ok, so where ever the fiber is coming from is setting the IP.
    So that's why you can't change it at the PC.
    The ipconfig release and renew only works for the local machine, not your connectivity feed.
    You have to find out what is setting the address at the fiber.
What does computer command "ipconf/release" do?
This command will flush the IP address from an active connection. The correct syntax is ipconfig /release *con* which will release all connections. If you just want to see if you can get a new address then use ipconfig /renew
Sep 03, 2014 | Lenovo ThinkCentre Computers & Internet
Tip
HOW TO CHANGE IP ADDRESS
To change your network IP address in Windows XP, Vista, or 7:
1. Press the Windows Key and R
2. Type command and press Enter. This loads your DOS prompt
3. Type ipconfig /release then press Enter. This disables your internet connection
4. Go to your desktop, and right-click on something called Network Place or My Network Places (If you're using Windows Vista or 7, look for the Network and Sharing Center through Control Panel)
5. Click Properties. You should now see something called Local Area Connection or something similar
6. Right-click on your connection (titled Local Area Connection if you're using an ethernet cable or Wireless Network Connection if you're on WiFi) and click Properties
7. Under the General tab, double-click on the Internet Protocol (TCP/IP)
8. A new window appears. On its own General tab, click the box beside Use the following IP address
9. Type in ones until you fill the box up (it should read 111.111.111.111)
10. Press Tab. You'll notice the Subnet Mask section automatically fill sup with numbers
11. Click OK
12. Click OK to bring you back to the "Local Area Connection" screen
13. Right-click Local Area Connection and Click on Properties again
14. Again, under the General tab, double-click on the Internet Protocol (TCP/IP)
15. Select Obtain an IP address automatically
16. Click OK
17. Click OK
18. Go back to your DOS prompt, type "ipconfig /renew" and press Enter. This restores your internet connection.
By now, the network should've assigned a new IP address to your computer automatically.
on Jul 22, 2010 | Computers & Internet
Wireless connection - can not renew the IP address
Here's what you can do Sometimes you can simply right-click the computer icon in the task bar near the clock of your XP desktop (If this icon is present). This will go through a process of resetting your IP address.
But if you do not have this option, you can go to START>RUN and type cmd. At the command line type ipconfig /release (or winipcfg /release in earlier versions of Windows). Then hit ENTER. Next, type ipconfig /renew and you should get a new IP address from the router.
If this doesn't work, renew the IP address. You will have to nullify the IP address on the PC, then shut the computer down. Next, unplug the cable modem for a couple of minutes, then plug it back in again. Once all of the modem lights are green, power up the PC again. It should automatically renew its IP at boot.
Unplug the router, then plug it back in AFTER you plug in the modem, but before you power up the PC. The router will need to supply the PC with a new IP address. Good luck, hope this helps or gives you something to try.
Apr 11, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Renewing ip address
To renew your IP, open a command prompt and type either one of the following:
1. ipconfig /renew (press enter)
or
2. ipconfig /release (press enter) -to release your current ip
ipconfig /renew (press enter) - to renew your IP
That should do it.
Dec 29, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
I cannot connect to the internet with my laptop Toshiba?
You need to get the IP address, domain and other info from you internet service provider to set up the connection again.
Aug 21, 2009 | Toshiba Equium 100 PC Desktop
Ho to dograde Acer Aspire M5641 From Vita To XP
please use another xp cd and try again their should be some problem with xp cd ,,
Mar 01, 2009 | Acer Aspire 5610-4648 Notebook
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
How to repair the laptop screen
i think is not the upgradation problem may be screen only , connect external monitor and check if it ok, problem in laptop screen
Mar 27, 2008 | Computers & Internet
WRT54G linksys router
The first thing I would do is check to make sure the desktop with XP has the network card set to "obtain an IP address automatically"
if it is set to obtain an ip address automatically, I need to know the following:
What is the IP addresss of the router?
What is the IP address of the Vista computer?
What is the IP address of the xp computer?
You can find the ip address by going to start, then run, then type cmd and hit enter. at a command prompt type: ipconfig and hit enter.
Feb 21, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
305 people viewed this question
David Payne
David Payne
