Question about Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill
How can I test whether the charger or battery id faulty. I live in Windhoek,Namibia
    Sergeant:
    Champion:
  • 250 Answers
You have to check You have to check the battery and charger for voltage with a volt meter. The charger should be putting out at least 14.5 volts and the battery should read 14 volts. There are metal contacks on the battery and on the charger inside the hole where you insert the battery.
Posted on Mar 11, 2011
Whe I switched a camera red light show but after 6 hours the battery does not charge
either the battery or your charger may be faulty, if you tested with another battery, then there may be snag in your charger, if you are using a separate charger, test it with a multi tester whether the needed out put volt is getting, if not the charger must be faulty.
Feb 19, 2016 | Cameras
How do I check if it's my Powakaddy battery or the charger is faulty as the battery on lasted 8 holes and the charger green light was on when fully charged
Batteries have a limited life and depending how old they are and what sort of life they have had depends on the likelihood of whether the battery or batteries are faulty or have a reduced capacity.
Being left discharged or semi-discharged for more than a few days, or a few weeks, operating in a hot climate, overheating during charging or being subjected to inappropriate loads are a few of the things that shorten the life of a battery or reduce it's capacity. A quality traction battery is good for around 500 charge/discharge cycles if it is operated in ideal conditions. Employing a short top-up charge whenever convenient can extend that number many times.
Considering what I have said it could be a good idea to replace the battery considering you need a fair level of reliability - there aren't many short cuts on the golf course.
Testing a battery properly is quite a long process even though there are hi-tech testers that claim to carry out in an instant what used to take a couple of weeks. Testing a wet battery is easier than testing a gel battery.
A digital voltmeter can provide a rule-of-thumb sort of test. Leaving the freshly charged battery to stand for several hours to disperse any surface charge the terminal voltage is then measured. A healthy fully-charged battery has 2.2 volts per cell. That is 13.2 volts for a 12 volt battery. A 12 volt battery that registers 12 volts is only half charged (or faulty) and of a limited practical use.
Less than 12.7 volts and the freshly charged battery needs replacing unless it is used for very light loads. 12.7 volts and above offers varying degrees of serviceability but less than 12.9 volts and the battery is past its prime.
Testing the charger thoroughly can also take some time and expertise but if the battery doesn't become any warmer than a baby's bathwater during charging and the terminal voltage of the battery while the charger is connected doesn't rise above the specifications for the charger, typically around 15 volts depending on charger type, the charger would seem to be doing the job.
Feb 28, 2015 | Health & Beauty
Kocaso nb1016a
The first thing that comes to mind is that either the charger or the battery is faulty. You can check whether the battery is retaining its charge properly or if it drains out quickly.
The Kocaso NB1016 specification states that it uses ...
"Power Device Type:AC, DC can DC can car charger". So you can test whether it can be charged from a car battery. If so, then your charger is at fault. If all else fails you'll have to contact Kocaso support for a software/firmware upgrade.
Feb 14, 2014 | Computers & Internet
My car has a computer box problem, it does not start, where and how can i fix it, took it 2 times to isuzu dealers in windhoek, namibia, but still it keeps on stucking in the middle of the road.. do you...
have you tried replacing it with an other? try one from a used one from a slavage unit, its cheeper than the dealer, when mounted check that all grounds are fasten ok.
Oct 09, 2009 | 1995 Isuzu Pickup
LCD screen is on, not in hibernating mode but does not show any letters, derections, description
I think you have a lose connection caused by rotation of the flip up lcd screen. My MP520 does the same, but the characters display half way down when closing. I have not got round to opening it up to get to the guubings yet.
Apr 15, 2009 | Office Equipment & Supplies
Re-installation of servoband, servo-piston, servo-washer
cant remove that washer
replace it
has to be there for functional reasons
i use this site for all my automatic repair and rebuild manuals
if that volvo not listed in the import lists ..use the "contact us "
ATSG Import Manuals
Mar 08, 2017 | 2002 Volvo S60
Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill Logo
490 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
