Question about Epson Stylus CX7800 All-In-One InkJet Printer
Epson cx7800 error e-04
Barely ever used and I get an error message saying there is a paper jam. Problem is there is no paper in the machine or the rollers. Everything appears fine when top is open. I have tried everything but a hammer.
  • 6 more comments
  • Anonymous Sep 14, 2008
    Me too!
  • Anonymous Sep 17, 2008
    Try a hammer, I have the same problem.
  • Anonymous Sep 18, 2008
    I hardly use it, never had issues with it. I was actually printing fine and the next page paper jam. Since then it will not print. I have done just about anything to just think about buying something different. I was a fan of Epson as I had a few others that are still alive so I convinced my husband to buy one instead of HP... guess I was wrong this time. We took it apart and there is nothing in there that causes the jam, we will most likely buy another printer :(
  • Anonymous Oct 07, 2008
    Mine started doing that too. Actually, now it changes between 'paper jam' error when there is no jam, and 'out of paper' when there is paper in it....now it just sends the paper through without printing it. Every 10-12 errors, it actually prints one! Ok, where is that $%^*$ hammer?!?!
  • Anonymous Nov 09, 2008
    I have the same problem. My printer showed paper jam and E-4 error. When I pressed enter, the paper flew through the printer with nothing printed on it. Now, the error message does not show but when I try to print the paper actually does jam up.
  • Anonymous Nov 27, 2008
    A IMPRESSORA FICA DANDO COMO C TIVESSE PAPEL ATOLADO....PODE ME AJUDAR A RESOLVER?
  • Anonymous Dec 31, 2008
    Yet another one with the same problem. Looks like these were made to self destruct in about 2 years.
  • jamesthe Feb 18, 2009
    I have this problem too..the printer part prints from the computer but is will not copy the E-04 Error show only on the Copy mode. This Printer has worked fine for the last Year or so..
Make sure the ink cover was down tight. Shut down the printer open it up and resecure the ink cover. That has fixed this error in many a case.
Posted on Dec 12, 2008
Best Solution: buy anthing but an epson
Posted on Oct 08, 2008
Yes, the hammer is the best solution. Mine started with the paper jam error when there was none, then it started saying there was no paper when there was paper in it, and now it just sends the paper straight through without printing anything. Yes, definately, the hammer!!!!!!!!
Epson sx438w e-02
did you check paper feed driver unit sensor in paper fixing fil or board
Feb 19, 2013 | Epson Stylus Sx438w
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
THE EPSON STYLUS CX7800 KEEPS SAYING THERE IS A PAPER JAM, BUT IT'S NOT. IT TRIES TO PULL THE PAPER THROUGH, THEN STOPS. IT DOES NOT ENTER FAR ENOUGH TO EVEN BE JAMMED. IT APPEARS THAT IT IS TRYING TO PULL...
The sensor lever was stuck and still blocking the sensor and that is the reason why it always say paper jam.You have to dismantle your printer if you do,you can find and trace the sensor where the paper is being inserted,most probably it is near the pick up roller (it is the one that gets the paper).
Sep 17, 2009 | Epson Stylus CX7800 All-In-One InkJet...
I do'nt see any paper being jammed.
when the message appear? Turn on printer or starting to print? If message appear at beginning turn on printer is caused by "something " slip at paper feeder. But if it appear at start to print, it caused by chip error? Do you use CISS chip?
Jun 25, 2009 | Epson CX7800 Stylus Color All-In-One...
Error 90 call for help
Your printer needs the attention of a service technician. Before then, you may try reinstalling your operating system or the printer driver or both.
Jun 18, 2009 | Epson Stylus CX7800 All-In-One InkJet...
E-04 Clear Paper Jam, no paper in printer
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 15, 2009 | Epson Stylus CX7800 Color Flatbed...
Epson CX7800 paper jam Error e04
There is paper jammed in the machine or something is blocking the sensor for the paper path.
Remove the obstruction (try a vacuum cleaner nozzle down the feed path) and the machine should be right again
Jul 04, 2008 | Office Equipment & Supplies
My Epson CX7800's Printer is broken.
chances are you are having an issue with the paper sensor mechanisms, check if there are obstruction or any foreign object that are actually preventing the paper to go through all the way to the right hand side of the printer. if there is non that is already a hardware issue:
Check this site: www.epson.com/loyalty try using this passcode LEOPARD and register.
Feb 17, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson all in one (printer/scanner)
Here is the link for all the documentation, troubleshooting and drivers for your printer. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58773&prodoid=56291070&infoType=Downloads&platform=Windows If you go through the troubleshooting guide, hopefully you will find an answer - with the info you gave I had no luck, but the procedure is quite detailed, so you may have more idea what answers to give. The next thing to try is to uninstall and reinstall the drivers - on the link above you can download the latest versions. This ,may solve the problem and is simple enough to do (ask for more help if you have trouble with this procedure). The only other thing that maybe worth doing is to give the whole machine a gentle shake just in case the scanner carriage mechanism is somehow jammed - sometimes a shake or a slap can free this. Hope this helps, if not please post again :)
Mar 21, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
1,303 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
