Question about Microwave Ovens
I have an electric range purchased in 2008. The model #CFEF358ES2 There is a number F11 flashing on the unit and the manual makes no reference to that number. Please advise the action I should take as the range is currently inoperable.
    Brigadier General:
  • 8,909 Answers
I cannot find any reference to F11 except "Call a service agent". Looks like that is the best option.
Posted on Mar 11, 2011
How do I disable the child lock on a Sharp R-891 Microwave?
It looks like from the "Home" Screem press "Information Desk" then "Useful Information" then "Child Lock" then "Set The Lock"
If you don't have a owner manual you can view online or download one here. Just put your model number in the search box
ManualsLib Makes it easy to find manuals online
Good Luck,
John
Sep 10, 2016 | Sharp Microwave Ovens
GE Range
Look at this example for common places where GE puts their model number so that you'll need to waste energy trying to look for it.
Sep 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge hood insert zvc36l1ss fan comes on by itself. When not cooking?
The switch is bad. That makes it a possible fire or electrical hazard.
You should replace the switch immediately, or at least turn off the breaker that supplies power to the unit.
Don't let a broken $20 part be responsible for burning your home to the ground, fix it!
Parts for this hood are at http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Range-hood-Parts/Model-ZVC36L1SS/0432/0122400
This shows you how to open it up and replace the parts: http://www.searspartsdirect.com/partsdirect/user-manuals/9235/ZVC36L1SS-GE-Parts-RANGE+HOOD-manual?pathRender=fromManualTabPage
Jul 26, 2014 | Microwave Ovens
How do I use my Griddle for the first time? We did not get a manual I would like one sent to us.
I can't help you with the manual because you did not provide the make and model number.
Typically, you wash the griddle with soap and water (DO NOT WASH ANY ELECTRICAL CONTROL UNIT!). Rinse and let dry if it has a non-stick coating. If it does not have a non-stick coating (bare metal), towel-dry the griddle, then put some vegetable oil on a paper towel and wipe the entire cooking surface so it is covered with a thin film of oil. Heat it to about 250 °F for about one on-off cycle on the electrical control. It is now "seasoned" and ready for use. If the griddle does not have an electric heater but is designed for use on a range-top burner, set the burner to just below medium heat and heat until water droplets splattered on the griddle boil off quickly.
May 30, 2011 | Microwave Ovens
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
My folks recently purchased a house with a Jenn-Air S160 electric grill-range/oven. The left hand side electric burner cartridge's back burner superheats on the low setting. I've switched the burner...
Sounds like the problem is in the control assy. especially if you switched the burnners and the problem remained. Go to the jenn-air website and see if they have a parts breakdown for your unit.
Record the model number of the unit before you search, you will need that info.
Apr 16, 2011 | Microwave Ovens
I have a GE Profile Spacemaker PVM 2070 SMSS and the button pad needs to be replaced for the vent and lights. Can this part be purchased?
Sadly on the 2070-series models, GE does not make separate parts available for the controller.
Only the control panel subassembly is available, and these range from a few hundred to several hundred dollars, depending on your full model number.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download GE owner's manuals and installation instructions here.
Jan 17, 2011 | GE Profile Spacemaker Over-the-Range...
Control panel non-responsive,time area flashing numbers only
You probably have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 04, 2010 | KitchenAid KHMC107BT Convection/Microwave...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
124 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
