Question about Char-Broil Commercial Stainless Steel Grill
Flame is yellow to green - Char-Broil Commercial Stainless Steel Grill
    Brigadier General:
  • 4,736 Answers
Sounds like you may have a tank of bad gas. Green is not a color related to the flame description of gas appliances. Blue, Yellow & Orange are pretty much it.
Posted on Mar 11, 2011
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
How to adjust side burner on weber grills
Burner could be blocked try cleaning the burner then you should be able to adjust air mix Lpg will a bit of yellow in the flame.
Jun 14, 2013 | Grilling
I have a Bryant furnace that is firing up then shutting right off.. The led is blinking green twice then yellow 4 times? What does this mean?
Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Feb 19, 2011 | Heating & Cooling
Yellow pilot flame
pilot is yellow cause its air mixture hole is blocked or you have something in pilot stem like a spider web i have had this problem on flame effect gas heaters during thier off months spiders get into pilot stem and create webs which can cause this the other reason is that the air mixture hole is blocked with carbon or something clean out to get blue flame, and an example of yellow flames in gas heaters is flame effect fires where i know a certain company cover air mixture hole on burner to get the flame more yellow and realistic looking but on a service i remove the foil they stick over hole making flames blue again, as it can cause the heater to carbon up to the extent of black glass with yellow flames
Nov 25, 2010 | Empire BF-10 Mid-Size Heater
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
Yellow flame from all carryover tubes. This grill is brand new
if the unit is running on natural gas, this is not unusual. if running off propane tank something is wrong with the regulator
Jul 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
Vulcan Oil Heater
move the collar away from the orifice for a blue flame. too little air causes incomplete combustion so you get the yellow tinging
May 18, 2008 | Heating & Cooling
Toyo 56
Hi ejohn,
There is no valuable, practical adjustment for the flame on a Toyo Stove. A yellow flame can be caused by several things. How old is the stove? When was the last tune-up? A dirty sooty carboned up stove will have a yellow flame. A breach in the flue pipe will cause a yellow flame. An incorrect installation of the flue and exhaust hoses/metal exhaust elbow will cause a yellow flame. In the last scenario, the intake will be hooked to the exhaust and the exhaust will be hooked to the intake ports of the flue pipe. A malfunctioning fuel pump can also cause a yellow flame. The wrong fuel can cause a yellow flame, too. Most likely, your stove is dirty and needs a tuneup. It should have a bright blue flame if it is clean, and operating correctly. You can download a manual at REE, Anchorage through a Google search. If you want a more detailed diagoses, write back and give me more detail and I can help you further. Toyotech
Jan 30, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Char-Broil Commercial Stainless Steel Grill Logo
146 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
