Question about Movado Watches
I have a Movado ESQ moon phase #8727862 and I want to know how much is the retail price for it. Can you direct me to any link?
5 Suggested Answers
  • 61 Answers
SOURCE: I just need to remove 2 links and I do not want to
Take this to a jeweler or pound out the pins with a paperclip width rod of steel or pin pusher and a hammer.
Posted on Oct 17, 2009
escapement
  • 2334 Answers
SOURCE: How do I remove links on a Movado elliptica?
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 09, 2010
  • 906 Answers
SOURCE: Set the moon phase on Longines
Good day Sir, here's the link below where you can find your users manual.
hope it will help you.
manual
have a nice day.
Posted on Jul 28, 2010
gemineye61
  • 831 Answers
SOURCE: How do I set the time, date, day and moon phase on
Here you go!
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
Best regards.
Posted on Aug 24, 2010
Hello where l can find the rubber straps(bracelt) for ESQ BLACKFIN 300m
Thank you for contacting FixYa.
The best place you can contact for replacement would be Movado itself by following the following link:
http://service.movadogroup.com/care.cfm
or you can also try:
http://www.watchbands.com/category.aspx,,categoryID,,754
Best regards. Jewel
Aug 31, 2010 | ESQ Blackfin 300m Dive Watch Black Dial...
I need more links for my watch
ESQ is Movado.
http://a3.geoserve.com/scripts/esrimap.dll?Name=L&Com=fo&Db=DLRMovall&Ds=Movado&Filt=User7%20LIKE%20%27_S%25%27
This link will provide you with an Authorized Service Center.
Jan 13, 2010 | Lucien Piccard 26024 Wrist Watch
I changed the battery in my esq swiss watch and can't get the back on the watch. What is the trick to re-installing the back
ooh, ESQ by Movado. These case backs are often pressure fit, just like Movado, and are notoriously difficult to reinstall. It sounds like it is going to take a watch press to install your caseback. This is an expensive tool which any jeweler that changes batteries will have. There is no real safe way to this without a press.
Now, I have just supposed that this is a pop off; if it is a screw on back then it would have had to have been unscrewed to get it off. If it is a screw-back then you will likely need to get a caseback wrench to tighten it down enough.
Oct 18, 2009 | ESQ Swiss Muse 07101116 Watch
I NEED TO ADD 2 LINKS TO MOVADO WATCHBAND .THE CASEBACK # ON WATCH IS 88.E2.887.2.the #on band is v144.g.2
An authorized Movado Retailer can order the links for you. you can locate a local retailer on www.movado.com
http://www.movado.com/FindARetailer.aspx?
Jan 21, 2009 | Watches
New band
You can either contact Movado directly (they make the esq watches) or you can ask any REAL jewelry store to contact the company for you and ask about this as long as they carry either Movado or Esq in their store (don't ask the jewelry counter at your local department store).
Dec 30, 2008 | ESQ Swiss Muse 07101116 Watch
Watches Logo
102 people viewed this question
Top Movado Watches Experts
Jimmy Accardi
Are you a Movado Watch Expert? Answer questions, earn points and help others
