Question about Hitachi 50VG825 TV
Our Hitachi combination projection color tv and dvd player 46W500 has sound but has no picture. The screen flashes green then purple. Any help would be greatly appreciated. Thanks
  • lindsay742 Mar 12, 2011
    The other day we were trying to hook up my laptop using the S-video cable to the Hitachi. I hooked up the laptop while it was on and the program was on too. And at that point the tv was still working but we could not view what was on the laptop on the tv. So I read up on hooking laptop to tv and it stated to connect the cables first then turn on the laptop. I am guessing doing the hook up wrong has created the problem? Cause the next time we went to use the tv we had the green screen then purple screen. I checked right now and the tv screen was purple then green then purple etc. What needs to be done? Thanks for your help.
  • Hitachi Master
  • 19,396 Answers
Hi.
If you have the Hitachi rear projection TV, then there are different defects that will result in sound but no picture. The purple light is not an error code.
First check if problem is affecting the signal from external DVD or any other external source. If the problem is only on one source, then the fault is a connection cable. If it happens only with the internal DVD, then the problem is the internal connection cable
More commonly you will get sound but no picture with all sources. In that case the first part to be tested is the board that supplies power to the lamp (someone calls it ballast). If the board is OK and powering the lamp, then the lamp must be replaced even if lamp light is not on. The ballast is an high voltage board-it must be tested by a technician.
If ballast does not get power, then the PSU must be tested. The PSU supplies power in different voltages. The DC line to lamp is not coming up. If PSU is OK and lamp ballast is OK, then problem is light engine or main controller.
Here all parts: Hitachi 46W500 Parts List
Here a service manual. A few dollars fee is required for download: Hitachi - 46W500 Service Manual
Regards.
Ginko.
Posted on Mar 11, 2011
  • Ginko
    Ginko Mar 12, 2011
    Hi.
    The laptop DVI port, as well as HDMI and USB port carries +5VDC power signal. If the laptop is on, an occasional short while plugging in can damage one of the ports, or even the main controller board.
    If the problem does not go away by disconnecting TV power cord for ten minutes, then there is some defective component inside the TV. Testing will start from terminal board, which includes the DVI and other input/output connectors on the TV.
    Testing must be done by a technician working at component level.
Convergence problem with hitachi 46w500 tv???
Never replace all the resistors--that is a mistake.
Real question here is: is convergence bad in EXACTLY THE SAME WAY AS BEFORE THE PARTS WERE REPLACED?
The only nasty remaining possible thing is the DCU in the set is bad or you somehow cleared its memory of the adjustments.
Jun 16, 2012 | Hitachi 46W500 46 in. TV/DVD Combo
My 46W500 Hitachi HDTv is blinking. The picture looks fine, but after about 10-15 seconds, on any given channel, the screen begins to blink. The blinking has a color pinkish tint. Can anyone help me out on...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
The tv model number is hitachi 46w500. the dvd picture is stuck on one screen and now the dvd won't eject.
Remove the power off and let the set rest for about few hours. Now try out to see if the DVD releases.
If the picture is still with the old memory of thelast scene then the processor has hung up.
You must have to release the DVD by opening panel if a reset of an overnight power on the set does not work.
Oct 30, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi 46W500
Have you tried pushing the "magic Focus" button?
Aug 22, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi tv projection
Need alittle more info . What is the model # . And does any of the lights on front come on or do you hear a click?
Feb 28, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Sound but no picture
If PIP works, have you tried to swap pictures. You may have a tuner out.
Jan 20, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Jan 10, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Won't turn off
Go to the panel (on the tv set), hit magic focus on there....then hold power button for several seconds long. It should go off and fix your problem.
Jan 22, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi 50VG825 TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
