Question about GE Refrigerators
Frost on coils in refrigerator. Refrigerator gets warm
    Sergeant:
    Champion:
  • 247 Answers
Try to adjust manually the defrost timer possible fail to rotate to on the defrost heater need to defrost the unit to circulate the cold air also check the evaporator fan if run smothly. then reset the unit unplug the unit after several minutes plug it on.
Posted on Mar 11, 2011
The fan is working. The fridge, freezer & coils are not iced up. There is good room for air circulation. I vacuumed most of the dust from the coils, etc. The compressor is just slightly warm to the...
Good day to you sir John,
A refrigerator or freezer that doesn't cool well enough may have a problem with its evaporator coils, condenser, or condenser fan motor. Frost build-up on evaporator coils, or condenser coils that are covered with dirt, dust, or lint can reduce how well a refrigerator can cool. If you notice ice getting thicker on the inside walls, inside bottom, or inside ceiling of the freezer, you have what is called a frost build-up. The problem is either with warm, moist air getting in through an old inefficient door gasket or the defrost system. Self-defrosting refrigerators have coils and a cooling fan that need to be cleaned regularly. If the coils get coated with any contaminants, they may not cool the refrigerator properly. The coils are usually thin and black and they go through fins that dissipate heat, just like a car's radiator. They are located behind the lower kick-panel or on the back of the refrigerator. To clean them, turn the power off and use this condenser coil cleaning brush, or this condenser coil cleaning brush, and your vacuum cleaner. Even if your coils are below the refrigerator, you won't be able to get to all the condenser coils from the front, so it's a good idea to pull the refrigerator out and clean the coils from the front and the rear of the refrigerator. Give the fan a dusting as well. Sometimes other things can be the reason behind poor cooling, like the condenser fan motor. Anytime the freezer fan is running, the condenser fan should also be running.
A frost build-up inside the refrigerator usually means that there is a problem in the self-defrost system. You may even have damaged door gaskets. When you open the refrigerator door, you also let in a blast of warm, often humid air. This moisture usually freezes onto the evaporator coils immediately. Self-defrost refrigerators are supposed to self-defrost between two and four times out of every 24 hour time-frame. They basically turn off for a few minutes several times a day. A defrost heater kicks on to melt any frost build-up on these coils, which allows the frost and ice to melt, then it drains off to the pan underneath most refrigerators. Unfortunately, when a defrost component fails, too much frost builds up on the evaporator coils. When this happens, the circulating fan can't draw air over these coils. With no air flow over the evaporator coils, the refrigerator compartment will lose its cool.
To determine if the self defrost system is faulty, it's best to remove all the food from the refrigerator and freezer, turn your thermostat to the Off setting, and just leave the doors open for 24 to 48 hours, and let the refrigerator defrost. Keep an eye out for an overflow of water from the drip pan on the bottom of the refrigerator.
After everything has completely melted away, set the thermostat back to a regular setting. If your refrigerator starts operating properly, the symptoms lead to there being a problem with one of three other components in the self-defrosting system, the defrost heater, the defrost timer, or the defrost thermostat.
If, after testing these components, the refrigerator still doesn't get your foods cool, there may be a problem with the refrigerant level and you will need to contact a professional appliance repair person.
I hope this solution will be helpful...
Please don't forget to rate my answer if it is helpful to keep me going..
Thanks for using fixya...
Oct 23, 2011 | Frigidaire PLHT217TA Top Freezer...
Hi, I have an Admiral Refrigerator Model Number RSCA207AAM. I think it was purchased over 12 years ago. The refrigerator part is not cooling enough. Can you tell me how old this refrigerator is? Is...
Good day!!!!
I hope this information will be helpful...Thank you for consulting fixya..
Aug 31, 2011 | Refrigerators
Refrigerator and freezer too warm; freezer has heavy frost in back of the compartment
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 09, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
It is a frost free refridgerator, but it frosts up and the refridgerator part doesn't cool as well. I end up having to "defrost" the freezer by turning it of or running a hair dryer in it to rid...
Refrigerator
heatman101
Jan 16, 2011 | Refrigerators
Top section fridge warm frost in freezer section compreesor loud
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 12, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer warm, can hear fan, water coming out
no frost in the back panel of freezer? did this happen all of a sudden? compressor hot? condensor coils dirty?
Jun 26, 2009 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerator is warm, but freezer works. Coils are frozen.
you are having a defrost problem, probably needs if it is a maytag, it probably needs a control.
Jun 15, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
