Question about Roper Refrigerators
I have a new 2007 Roper Refrigerator with a top freezer. The door of the refrigerator does not shut correctly. I can see the light when I look between the freezer door and refrigerator door. If I lift and shot the door it goes the light goes out. I cannot see how to make an ajustment to the door
  • 828 Answers
Generally speaking. Refrigerator door are assembled from bottom to top. Remove the cover on the top hinge of the freezer door. Remove the top hinge and lift the door to remove. You will now see the top hinge for the refrigerator door. This should be adjustable by loosening the screws and move it toward the outer edge of the refrigerator side. Tighten the screws and lock it in place. Reassemble the freezer door in the reverse order that you removed it. That should take care of the problem.
You can observe the top edge of the refrigerator door in the closed position when you have the freezer door removed.
Posted on Jul 31, 2008
What are the dimensions for roper refrigerator rt18dkxfw01
The problem is a no defrost.Open the fridge door and look at the control box where the thermostat is located.Look from the underside of the box you will see two small screws and a small hole , Use a flat screwdriver and turn the small cog on the defrost timer till the fridge shuts off.Wait 15 min and tell me if the coils start to thaw
Custom Headlights For Audi
Jun 11, 2012 | Roper RT21AKXKQ Top Freezer Refrigerator
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper top freezer works but not the bottom
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 16, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Freezer leaks. Into freezer and refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Nov 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerator/freezer door rusting and leaking at
Use DeBruce polish, we find them at
Mar 22, 2009 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
155 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
