Question about Maytag Neptune MDG5500AW Gas Dryer
Will not start
Interior light goes on. Display lights not on. Checked plug, fuse, vents. Help!
Thanks
  • Anonymous Aug 15, 2008
    same problem as the other writer.  light on inside dryer, display not on and none of the buttons work.  noticed that the display panel is warm though.
  • 60 Answers
Check that the belt is not broken if thats ok then check the door switch to see if that is working properly if that is ok then the problem most likely is the electronic control
Posted on Nov 12, 2008
Refrigerator interior light
Not sure about external light, but bulb may be loose . Have you checked mthe plug conections to make sure they are all tight? If all conections are good try a different outlet / socket.
Jan 28, 2014 | Candy Refrigerators
97 honda cvic dx cranks but wont start and no lights or radio work
Wires,coils,fuel filter,check fuses,relays,battery connection.
Jun 14, 2013 | Cars & Trucks
I own a 1999 Mercury Grand Marquis and I need some help. With the headlight switch in the off position all dash and display lights including the digital clock work fine, but the display on the radio and...
There are two 15amp fuses marked 4 and 8 that provide power to the light control module. If those fuses are good, and those circuits have power, the problem may be with the control module. The module provides power to the dash lights.
You may need a shop to trace the circuits and find the problem.
Aug 16, 2012 | Cars & Trucks
Battery problems
Well, something is on if the battery is dead. Pull the interior light fuse, and the clock fuse, disconnect the negative battery cable and put a 12 volt test light between the battery terminal and the cable...Likely it will light. Then pull fuses one at a time and observe if the light goes out. Keep disconnecting until you get the light to go out. Do not rule out the new alternator, stuff happens.
Feb 04, 2012 | Cars & Trucks
My battery has been checked and is fine, but the battery will go dead within approximately 48 hours if the car is not started and run. I checked all of the draw from the battery on each fuse and the #9...
TO CHECK FOR A BATTERY DRAIN. TURN OFF EVERY SWITCH IN THE CAR. CLOSE THE GLOVE COMPARTMENT. MAKE SURE THE LITE IN THERE IS GOING OUT. OPEN THE HOOD CLOSE ALL OF THE DOORS. MAKE SURE ALL OF THE COURTESY LIGHTS ARE GOING OUT. DISCONNECT ANY UNDER HOOD LIGHTS. DISCONNECT NEG. BATTERY CABLE. USE A 12 VOLT TEST LIGHT, FASTEN ONE END TO THE NEGATIVE BATTERY TERMINAL, FASTEN THE OTHER END TO A METAL PART OF THE MOTOR. IF THE LIGHT COMES ON, THERE IS A BATTERY DRAIN. NO LIGHT, NO DRAIN. IF THE LIGHT IS ON, PULL EACH FUSE, BIG & SMALL, ONE AT A TIME, OUT OF THE FUSEBOX THAT IS NEAR THE BATTERY. WHICHEVER FUSE MAKES THE LIGHT GO OUT IS CAUSING THE DRAIN. IF THE LIGHT STAYS ON THROUGHOUT THE FUSE PULLING, DISCONNECT THE ALTERNATOR. IF THERE IS SOMETHING WRONG IN THE ALTERNATOR, IT CAN DRAIN THE BATTERY WHILE SITTING STILL, EVEN THOUGH IT IS CHARGING THE BATTERY WHILE YOU ARE DRIVING. GOOD LUCK
Jan 14, 2011 | 1993 Mercedes-Benz E-Class
1997 Buick Park Avenue Ultra. Replaced battery,
recheck your body ground may have surface rust on bolt, body, or connection
Aug 18, 2009 | Buick Park Avenue Cars & Trucks
Interior dash lights
you can go to radio shack or a place that sells stereo equipment and get an installation kit and I hope he did not cut the plugs off the old radio because it would be easy all you would have to do is plug in your installation kit to your old plugs and it will tell you which wire goes where most kits are around $15.00
Jan 23, 2009 | 1997 Honda Civic
99 Beetle - brake lights and interior temp lights out
there is a possibility that they did check them if they arent then look for a short
Nov 25, 2008 | 2001 Volkswagen Beetle
Interior light's not working
1999 vw passat, no interior lights , no door lights ,no lights on sun visors no boot light.all lights worked 2 months ago ,they all came on again for about 5 minutes last week,and have not worked since ,every thing else works ok .can you help. thanks PETER
Nov 03, 2008 | 1999 Volkswagen Passat
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Maytag Neptune MDG5500AW Gas Dryer Logo
48 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
