Question about Timex Overstock Ironman 350 Upright Exercise Bike Exercise Bikes
Accufit 1500 exercise bike. It works great. Wondering how to operate deice between the handlebars that connects to a cable running into the wheel area of the bike?
Need pedals for resistant exercise bike with movable handlebars
ive found that bike stores (even online ones) have pedals for decathalon bikes that have the foot straps these should ***** right on to your stationary bike just the same , I will say there a bit pricey !!!
Apr 13, 2016 | Exercise & Fitness
How to assemble a weslo pursuit ct 4.2 bike video
Weslo Pursuit CT 4.2 Recumbent Cycle: Relaxing Exercise ...
www.kmart.com > ... > Recumbent Cycles
KmartSep 30, 2012 - Arts & Crafts · Video Games · Learning & Development · Stuffed Animals & Plush · Musical ... Weslo Pursuit CT 4.2 Recumbent Cycle 1 ... With a Weslo recumbent bike you can approach exercise with ease. .... Like all in box items it takes awhile to assemble, but works great, and great value for the money.
Weslo Exercise Bike - YouTube
? 2:55
https://www.youtube.com/watch?v=2ZLzpsk4BdE
Dec 22, 2014 - Uploaded by ReviewTube
Weslo Pursuit CT 2.0 R Exercise Bike http://amzn.to/1vgiQjF ...bike assembly,weslo exercise bike amazon ...
Weslo Pursuit CT 42 Recumbent Exercise Bike ... - YouTube
? 1:41
https://www.youtube.com/watch?v=tYdlVsnDNQo
Aug 20, 2015 - Uploaded by Geraldine T. Lane
SEE MORE Best Sellers in Exercise Bikes http://amzn.to/1frY7Yr The 3 Week Diet is an ... Weslo Pursuit CT 42 ...
Weslo Exercise Bike Product Support ' ManualsOnline.
Jan 17, 2016 | Weslo PURSUIT CT 4.2 Recumbent Cycle
How do you change the battery on the leisurewise pro fitness exercise bike
Disconnect the small jack plug from the small display unit on the handlebars. Remove the display from the handlebars undoing the two small screws, the gently prise the front of the unit of exposing the small printed circuit board on which there are two button batteries ( LR 54 available from ebay or almost anywhere else ) Replace batteries and reassemble to Bike
Apr 08, 2013 | Exercise & Fitness
What are the different types of exercise bikes?
There are three types of exercise bikes: upright bikes, dual-action bikes, and recumbent bikes. Upright bikes are standard exercise bikes that allow you to only use your legs (regular bicycling movement). Dual-action bikes allow you to workout your upper body as well by providing moveable handlebars. Recumbent bikes feature a bucket seat and the ability to recline while pedaling.
Aug 12, 2012 | Exercise & Fitness
What is a mini exercise bike?
A miniexercise bike is a bike with pedals and resistance parts only. It has no handlebarsor seat. You can use it while you sit on a regular chair and you can move thepedals with your hands for arm exercise.
Jul 30, 2012 | Exercise & Fitness
I need to remove the rt.handlebar throttle grip and replace it. need some pictures.
If you want pictures, I'm afraid that you'll have to purchase a manual somewhere. This forum will only allow me to send a picture of 150Kb size. Replacing the throttle grips is not difficult.
First, loosen the locknuts on the throttle and idle cables at the twist grip. Adjust the adjuster barrel inwards all the way getting as much slack as possible. Now, loosen the bolts holding the front master cylinder onto the handlebars and slide it towards the center of the bars just a bit. Remove the two bolts that hold the right handlebar switch housing together. Carefully lift the top portion of the switch housing and move it towards the front of the bike exposing the throttle twist grip. Work each of the cables out of the nylon wheel of the twist grip. Do not loose the barrels that go on the ends of each cable. Once you have the cables loose from the wheel, lower the lower switch housing and remove the right grip from the handlebar.
Now, take the new grip and apply a coating of white lithium grease to the wheel part and the inside of the throttle sleeve in the grip. Put a coating of grease on the handlebar end where the sleeve rides as well. Slide the throttle sleeve and grip onto the handlebars. Bring the lower switch half up and reconnect the cables to the throttle wheel. Carefully reposition the top half to the switch housing and make sure that no wires are being pinched. Install the two bolts but don't tighten. Slide the throttle grip all the way up on the handlebars and then back off about a 1/4" or so. Tighten the two bolts. Now, adjust the two cables to where they each have just a bit of slack. Turn the throttle grip to the wide open position and release it. The throttle should snap shut. If not, work with it until you get it to where it does. Once operating properly, reposition the front brake master cylinder.
Make sure your throttle operates properly. An improperly operating throttle control can cause lose of control of the bike resulting in serious injury or death.
Good Luck
Steve
Sep 06, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Handlebar on my reebok rb1000 exercise bike has snapped, where can i get a replacement ?
i have a reebok rb1000 exercise bike when i adjust the load up the resistance doesnt change. can anyone help
Apr 30, 2009 | Cycling
Vibration in handlebars/forks??
Front end vibration can be caused by front rim/tire out of balance, worn wheel bearing(s), bent front rim, or fork misalignment.
Since you recently had fork work done, I would first check the forks for proper alignment, then have the bike on a stand and spin the wheel to see if there is wobbling. To check for bearing wear, while the front is off the ground, try to rock the wheel from side to side. If you can feel or see movement, you will need new bearings.
Hope this helps
Mar 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
Timex Overstock Ironman 350 Upright Exercise Bike Exercise Bikes Logo
354 people viewed this question
Top Timex Exercise & Fitness Experts
Dennis Fitzsimmons
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Timex Exercise and Fitnes Expert? Answer questions, earn points and help others
