Question about Microwave Ovens
Need to know how to run new belt round the drum an tensioner
    Brigadier General:
  • 8,909 Answers
If you look where the tensioner is and release the locking bolt, put the belt on and retension it whilst tightening up the locking bolts.
A similar system to the altenator and fan belt on a car engine.
Posted on Mar 11, 2011
Frigidaire prof. series microwave PLMBZ209GCA not working. Display comes on. No sound (fan). Dont know if microwaving function is working properly or not. Any suggestions?
Two things could have happen to your machine.
One the magnetron is dead and needs replacement.
Second the high tension power which supplies power to the magnetron could have been screwed up and need to be replaced or repaired.
The fact that the fan is not running I suspect it may be a power board issue.
Apr 17, 2014 | Frigidaire PLMV169DC Microwave Oven
My dryer has started blowing cold air ?
The heater section is located behind the drum and consists of resistance wire coils suspended in ceramic insulators. The heater section provides the heat to dry your clothes. The GE/Hotpoint dryer has two coils; one for low heat and both for high heat. If your dryer's performance is unimpressive in the high heat settings it may have lost one set of coils and if you get no heat, you may have lost them both!
Procedures for Gathering Confirming Data
  1. Disconnect the power cord and move the dryer far enough away from the wall that you can tip the top up and it will stay there.
  2. There are screws holding the top of dryer down. Use a Torx #15 screwdriver to remove the screws. Lift the top up and swing it back against the wall or whatever is behind the dryer.
  3. Verify again that the power cord is unplugged.
  4. Examine the high limit thermostat on the top of the heater shroud behind the drum. Check for continuity through this thermostat. Go to the thermostat section for further fault verification and replacement information.
  5. Locate the 3 insulated studs and check for continuity between them. Put your ohmmeter in the lowest resistance range and measure the resistance between the three heater element terminals. If you read 18 to 20 ohms, the heater element is OK. If your meter doesn't move, the coils may be broken and you need to proceed on to their replacement. If you don't have an ohmmeter proceed on to the replacement procedure where you will remove the drum and you can examine the coils for broken heater wires.
Tools Required
  • An ohmmeter would be nice but is optional
  • 5/16 inch nut driver
  • No. 15 Torx screw driver
  • Wire cutters are handy for getting the old coils off and needle nosed pliers are handy for getting the new coil wires on the terminals
Parts Required
  • GE dryer element WE11X260 coil kit. I recommend replacing both coils even if only one is open.
Procedures for Replacing the Heater Coils
  1. If you have skipped the data gathering steps above, unplug the dryer, disconnect the dryer vent and pull the dryer far enough away from the wall to get behind it.
  2. Use a 5/16 inch nut driver to remove about 10 sheet metal screws from the rear access panel. Remove the panel and slide it down the power cord to get it out of the way.
  3. Make a little drawing of how the belt is routed around the idler pulley and the motor pulley. Reach in and relieve the tension on the belt by moving the idler pulley away from the belt. Slip the belt off the motor pulley and idler pulley.
  4. Locate the metal plate on the back of the dryer behind the drum. Use a 5/16 inch nut driver to remove the screws and then the panel.
  5. Use a small screw driver to pry the e-clip off the end of the drum shaft. Keep a finger on this e-clip as you ease it out or it will fly away and you will have to hunt for it. Carefully remove the three washers on the end of the shaft. The drum is now free to slide out of the rear bearing.
  6. Use a 5/16 inch nutdriver to remove the two screws inside the cabinet, near the top on either side that hold the front of the cabinet on.
  7. Lift the front off the two screws down at the bottom and swing the front around to the right without disconnecting any wires and lean it up against the side of the cabinet.
  8. Grip the drum with one hand at the rear and the other hand at the front. Be careful not to cut yourself on the razor sharp edges on the porcelain coated drum. Pull the drum forward to clear the rear bearings and then lift it up and out. Leave the belt on it and set it aside.
  9. (Figure 1) Now you have a good view of the heater shroud and coils. It will be easy to locate the breaks in the coils.
  10. Remove the broken coils. This task is made easier by cutting up the old coils into several pieces and carefully pulling them through the standoff insulators. Be gentle with the insulators as they are fragile.
  11. If these were original coils, the ends of the coils will be welded to the terminal bolts. Cut the wires off and remove the old terminal bolts by loosening the outer nut and disassembling the insulators. If the old terminals have the wires sandwiched between two nuts, loosen the nut on the end of the terminal. Again, be careful not to put too much torque on the nuts or you will break the insulators. Remove the remaining old wires.
  12. Prepare the coils for restringing by stretching them to specific lengths. Stretch the inside coil to 42 1/2 inches and the outer coil to 49 1/2 inches. These lengths are for a relaxed coil. It is better to have the coils too short than too long. If you stretch them too far, the coils will sag down and touch the metal heater shroud and burn up.
  13. Install the new terminal bolts through the insulators. Be careful not to break an insulator. You can't safely install the terminals with broken insulators and another trip down to the parts store to get new ones will slow down your repair a bunch.
  14. (Figure 2) Start threading the new coils through the insulators on the side opposite the terminals and work in both directions toward the terminals.
  15. (Figure 3) Note that both coils are connected to the top terminal and the other two ends are connected to the remaining two terminals.
  16. Use a needle nose pliers to wind the wires around the terminals between two washers and nuts.
  17. Slide the drum into its rear bearing
  18. Replace the three washers and the e-clip on the drum shaft in back of the dryer. Replace the bearing cover plate.
  19. Loop the belt behind the idler pulley, pull it back and then loop the belt around the motor pulley.
  20. Replace the rear panel and the dryer vent.
  21. Swing the front panel around and position it on the two lower screws. Use a 5/16 inch nut driver to replace the two sheet metal screws at the top.
  22. Lower the top and secure it with the 4 Torx screws.
  23. Plug in the power cord and check for proper operation.
Aug 03, 2011 | Indesit Microwave Ovens
Turn table not turning round but heating ok
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
May 18, 2011 | Microwave Ovens
The dryer is heating but the drum has stopped revolving what could the problem be and is it simple to fix.
Your dryer may have broken its belt, or the motor may have died.
A broken belt is "easy" to fix (if you've done a few), and not too expensive (if you do it yourself).
Replacing a motor is a little more involved (the drum has to be removed), and very expensive when
doing it yourself, and if you're not going to replace the motor yourself, it may be more cost-effective to replace the appliance rather than pay a technician to replace the motor.
A major appliance (dryer/washer) should last 10-11 years.
May 13, 2011 | Microwave Ovens
N need to know how to run new belt round the drum an tensioner on my zanussi conderser dryer tc 481 w
Mar 11, 2011 | Microwave Ovens
What is the easy way to fit a drive belt to a zanussi washing machine fla1001w
Disconnect from the mains.
Remove the back, slacken the clamp bolts holding the tension on the old belt next to the motor.
Fit the new belt, tighten the tension on the belt and tighten the clamp bolts.
Feb 23, 2011 | Microwave Ovens
Turntable does not rotate
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Aug 07, 2010 | Viking DMOC205 Microwave Oven
The turntable on our Whirlpool VT256 oven has
it could be 1 of 3 things here 1 the coupling under the plate mat be warn or broken inside so the shaft of the motor maybe turning but not turning the plate take the plate out and put a cup of water in the unit and see if coupling moves without the plate if not thn see if you can remove the coupling and repeat the test if you can see the motor shaft moving thn u need a new coupling, if not thn you may need a new motor to test th motor you will need to turn the unit on it side remove the plate first on the underside on the unit round where motor is you will see a plate this will round or square you need to cut this away to expose the motor dont throw it away as you need to refit if after, it turns round and you screw it back on, when you have found the motor remove and replace it albeit the motor is powered by the pcb it is unlikely to be the pcb as the motor runs all the time so they do ware out also do look to see if your unit has a turn table switch off button on the controls or in the manual hope this helps and dont forget to unplug ur unit from the mains.
Oct 17, 2009 | Microwave Ovens
Turntable won't turn
Hi , unscrew the cover check belt are tear / if tear replace belt , lose the belt tensioner if it has , if not just install incline belt into vevil of pulley.
Jan 15, 2008 | Kenmore 63252 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
