Question about HP Compaq Evo n610c Notebook
Compac Evo N610c - 2Mhz - 1 GB ram - Windows XP SP2 Blinking charging light went out and computer won't start up again. Checked power suplly (18,57v dc) Replaced with another power supply, replaced the battery with a brand new one - fully charged: nothing seems to help: computers is completely dead? Help wanted.
  • 492 Answers
Your computer has an open circuit on the system board. If you have data on the machine you can remove the hard drive and connect it to a PC, Sorry I can't think of a more elegant solution. I hope I'm wrong.
Posted on Mar 11, 2011
Compaq evo n610c 1gb ram is support for windows 7
Not at all!!
I've installed Windows7 in my n610c (with !gb ram) and my laptop is perfectly working.
Windows 7 is not the 'awful' Vista!!!
The most important things are W7 drivers for this laptop. In order to obtain these drivers, you've to download and install 7zip, then you've to expand in folders the exe files of audio ,video, etc.  drivers of windows xp, and let the system find the suitable drivers..
InstallingXP drivers (exe files) in W7  is not possible!
Also ram may be increased over 1Gb, but you've to install the O.S.
after having upgraded your ram, otherwise graphic card will be not working, even reinstallig its driver!!!
I've just made these operations in two Compaq evo n610c, successfully.
I'd  a problem only for Infrared port, but I've fixed it 'asking' system to find the driver into an external usb HDD full of drivers of various PCs. After a few time , also Infrared port driver was OK.
I've made a backup od windows7 drivers (you may use double driver(free) or Windriver Ghost (not free), in order to backup w7 drivers.
Regards
D.
Apr 18, 2010 | Compaq Evo N610C Notebook
Hello my compaq evo n610c don't start with power cord & battery
1>NEEDS TO TRY RESEATING OF THE RAM(SWAP THE RAM WHILE PLACING THEM BACK IN) AND THEN TRY TURNING ON THE COMPUTER
2> IF THIS DOES NOT WORK THEN NEEDS TO REPLACE THE MOTHERBOARD
BEST OF LUCK
Feb 08, 2010 | HP Compaq Evo n610c Notebook
Compaq evo n610c battery not charging
Dear All,
As per your asking that question the conclussion is there is an problem with battrey not on mother borad either problem is in Adpter connector please check out that adpter conncetor or else in the power connector in your computer iam telling you that there is an no problem in mother borad 100% suerly i tell you,
Regards
Vishwanath.K
Mar 11, 2009 | Dell Microsoft Windows XP Home Edition
GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
Dec 30, 2008 | Nvidia GeForce 6600 256MB 8X AGP Video...
How much more memory can I install
This laptop can support up to a max of 1 GB of RAM , so if you buy 1 stick of 1 GB of RAM you need to take out the 768 MB and just put the 1 stick of 1 GB RAM, or your other option is to buy a 256 MB of RMA so your computer will still have a max of 1 GB of RAM and that would be cheaper and you can still use your old RMA on your laptop , this is the lin for the complete specs of your laptop http://www.dealtime.com/xPF-Compaq-Refurbished-COMPAQ-P4-M-1-8GHZ-256MB-30GB-14-1-TFT-CDRW-W-XP
Hope that helps...........
Sep 28, 2008 | Compaq Evo N610C Notebook
How to format evo n610c without using diskettes?
Contact HP.com and see what it costs to get a set of restore disks for your computer. Windows XP was discontinued on July 1st but you might find a computer store out there that has a set for sale.
Jul 19, 2008 | Compaq Evo N610C Notebook
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce: http://www.memorystock.com/memory/CompaqEvoN610C.html)
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
http://www.pcfixreview.com/blog/2007/07/12/bad-pool-caller/
http://www.registrysimple.com/bad-pool-caller-fix.php
May 08, 2008 | Compaq Evo N610C Notebook
I can´t turn it on
check ur pwer plan settins in windows xp chose default settings
Dec 03, 2007 | Compaq Evo N610C Notebook
Compaq EVO N610c
Hey there i might be young im 14 years old but i have the same laptop (Compaq N610c) and i had the same problem i found out that if you take the ram out and rub the small golden plates with a rubber then place it back (the ram is found next to the mouse pad) i then powered the laptop up without the hard drive i then took the battery several times and powered up it then started working again within 5 mins of taking the battery in and then taking it out again it then starting to power up with the screen showing the logo at the begining after it had shown the logo i turned it off then inserted the hard drive back into the laptop and powered up it worked and is still working now Hope This Helps :D My Email Adress Is znet-productions@hotmail.co.uk
if you have anymore problems.
Sep 11, 2007 | HP Compaq Evo n610c Notebook
HP Compaq Evo n610c Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
