Question about Dishwashers
Its on all the time and dosnt allow the dishwasher to function
    President:
  • 1,140 Answers
Hello there,
Unfortunately, your description of the problem doesn't include some essential details:
1. What is "on all the time"?
2. What is the brand and model number of the dishwasher?
Please reply to me with these details by clicking on "Add a Comment" below your question. Please include any other details related to the fault that will assist us in solving your problem.
Thanks,
BElectric
Posted on Mar 11, 2011
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Mowcart 66 break/clutch dosnt work properly and chain keeps coming off
Loosen adjuster plates where rear axle mounts to frame,they should be elongated slots to allow chain to be adjusted and alig ned,you can also adjust belt under body for clutch/brake function..
Jul 25, 2014 | McCulloch Riding Mower Briggs 20 HP V-Twin...
Kenmore ultra wash dishwasher only half of the lights light up when pressed when press start nothing happens
Do you mean only half of the lights that you push stay on ? If I try to push in too many buttons at the same time, or the cycles I push don't function together, that some of them stay off because they aren't programmed to run at the same time. And the machine is set up to not allow you to expect it to do all the functions during the same cycle.
Jul 19, 2014 | Kenmore 665
Dishwasher
Your heating element is not working, It could be one of 3 things.
1. Broken solder joint in the electronics (common on this model)
2. Broken thermal overload sensor
3. Faulty Element (not very common)
I'd pull the front off and have a look at the electronics and take it from there.
Mar 05, 2012 | Hoover HED661280 Dishwasher
Soap dispencer door dosnt seem to be opening at the right time. i find the soap undisolved in the bottom of washer, and dishes are not clean.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 09, 2011 | GE Nautilus 24" Built-in Dishwasher
Dosnt clean very good ?
It could be a build up of grease in the filter OR the dishwasher may need a cleaner run through to clean out any grease in th pipes (best done about once a month )
Jan 18, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
Doesnt clean everything , leaves residue in
check the water connection that goes to the machine, if there isnt enough water getting into the machine then it dosnt clean as well.
the connection might be a little bit clogged.
Apr 20, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Neff built in dishwasher
these arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Nov 10, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
