Question about Garmin nuvi 885T GPS Receiver
How do I reset my garmin 885? I would like to reset to the original stage. Please help.
  • 109 Answers
This procedure has been known to (but doesn't always) delete your favorites so back them up beforehand: From the nuvi drive, copy x:/Garmin/GPX/current.gpx to your backup location. After the hard reset, copy current.gpx back to the same folder on the nuvi but rename it temp.gpx (important). On the next power cycle, the favorites will be read from temp.gpx into the non-user accessible memory area on the nuvi where they are actually stored (current.gpx is only a shadowed backup of your favorites)
Power the unit off. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears. Press "yes" and the unit will reboot. Reset all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
Posted on Mar 12, 2011
My Garmin nuvi 1450 shows only Garmin logo all the time. My PC can not detectet it. It hapend after update map. Please, need help. Thanks
This answer should help you: Garmin Nuvi 1450 Hard Reset
If your GPS is hanging on startup, you can try to factory reset it, which will revert all settings to originals, and usually make it boot again. Then you can re-update the software and maps.
If you aren't able to factory reset the device, it may have permanently failed and be unable to reset at all. It's probably not fixable.
Mar 13, 2014 | GPS
805 series problem - cant re-start it.
Try performing a reset on the Nuvi.
A soft reset is done with the Nuvi on battery power, slide the power switch to the left and hold it there for at least 10 seconds.
A hard reset will reset the Nuvi back to factory defaults. Before performing the hard reset, all user information should be backed up.
The hard reset is done with the Nuvi off, press and hold the bottom right corner of the screen and turn the Nuvi on while doing so. A prompt will appear asking if you want to clear the user data.
Also run the Garmin WebUpdater to load or reload the latest software as this will usually fix any issues.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Dec 12, 2011 | Garmin Nuvi 800, 850, 855, 860, 880,...
I fogot my Garmin nuvi 310 pin code. So please help me to unlock that.
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
Aug 30, 2011 | Garmin nuvi 310 Car GPS Receiver
I did not set a pin for my garmin but now it is asking for one. i tried to do a hard reset but that did not let me through. can i just re register it? please help
The reset will not unlock the unit.
http://www.garmin.com/us/support/contact
Jul 31, 2011 | Garmin nuvi 1300 Car GPS Receiver
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
I have a Garmin 885 the sceen does not work. touch keys do not work. I cannot get past the Garmin start up when plugged in . when I unplug it I get the warning page and select ok and get pge with wheree ti...
I recommend attempting a hard reset of your Garmin Nuvi 885.
Then I would upgrade the system software to the latest version. This often brings back unresponsive Nuvis.
Perform the Hard Reset
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  4. Press "yes" and the unit will reboot.
Upgrade the System Software
The upgrade software is a download available from Garmin. Installation steps are detailed here.
I hope that helps.
Dec 30, 2009 | Garmin Nuvi 660 GPS Receiver
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Unable to program a new address into my Garmin nuvi 1300T. it will turn on but will not let me get pass the agreement stage Reset it back to the default settings, help!!!
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Nov 03, 2009 | Garmin Nuvi 350 Car GPS Receiver
My garmin is locking up
There is a reset button on your garmin which you will find recessed into the case of the unit. You need something like the nib of a pen to be able to depress it. You can try depressing it and hold it in until it begins and then cycles through the reset process.
You may find that this resolves the problem of locking up.
Hope this helps.
Jun 24, 2009 | Garmin nuvi 885T GPS Receiver
Garmin nuvi 885T GPS Receiver Logo
336 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
