Question about H&B CA-5555 Car CD/ MP3 Player
Hello My name is Niaina , My car radio H&B CA 5555 has no sound , immediatly after the power on ,the message is tel mute the pink cable 'tel mute' is already disconnected , please ,could help me ?
How can I get sound from my radio
If a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp. So
remove all cables and put them back to the radio & connect the speakers one by one to see if it works or mutes again
Sep 30, 2016 | Jensen Jta-475 Cd Player /turntable...
Call mode enables right after power up and radio does not have a phone wired into the radio.
sounds like it is wired wrong check that the wire for the tel mute wire(brown) is not connected to a live wire. let me know how you go.
Jan 26, 2011 | Kenwood KDC-MP342U Car CD Player
What wire do i use to mute the radio when the phone rings?
It is only one specific wire, what kind of radio is it? They can all be different, but normally it has a cell phone mute wire which could be a light blue or pink wire not to be confused with the amp turn on or power antenna wire.
Good luck.
Jun 12, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Radio mute and displays tel
for some reason the radio thinks you have a phone call and has muted the phone
Apr 25, 2010 | Car Audio & Video
Tel.mute
The Tel Mute function is controlled by the pink wire in the loom. Make sure it is not connected to anything.
A capacitor inside the unit has also known to cause this problem when it goes bad. This will have to be repaired by a tech. but you can le tthem know to look for C719 or C711 (I think C711 is printed on the pcb)
Apr 27, 2009 | Rockford Fosgate RFX-9210 CD Player
Tel mute
A capacitor inside the unit has also known to cause this problem when it goes bad. This will have to be repaired by a tech. but you can let them know to look for C719 or C711 (I think C711 is printed on the pcb) .
The manual can be downloaded from Rockford website.
Radio wiring
Sounds like you have been misled as radios do not interfere with any other system in the car.Are you saying Tel mute because of phone hooked into it and muting or its just stopped putting out sound?A car radio is relatively easy to remove and check without unplugging.Pull radio out enough to check that all the plugs are plugged in and check wether an amplifier has been installed as its usualy an amp that stops the output of sound.If no amp fitted you will need to determine if you are getting a signal out from the speaker wires at the stereo plug,use spare speaker and test all the speaker output wires and if no power you may need to get it repaired/replaced.Not sure with your year/model but some radios do have a mute facility built in so check every function on your stereo very carefully .
Nov 26, 2008 | 1992 Jaguar XJ6
Wire diagram i think
pink wire if its to go to ground then any metal is ground or negative not live in other words they say the handbrake so you cant use it whilst driving so any metal should do for this ok.
Are you wiring it to amp or not?
Also the mute only wires into say phone cradle or something that would mute the stereo say if you had phone in craddle this would mute the sound so you could here the call. so not needed unless you have phone craddle.
If the two lives are wired in and the ground black when you earth the pink then it should switch on let me know if this happens.
Auto ant is for the arial on car if this goes up and down on motor if not then its not needed
Ill check on dimmer/illumination ok but bare with me for couple of hours just popping out but will get back to you then ok
Apr 19, 2008 | Jensen VM9410 Car DVD Player
Player says "CALL" upon startup
It sounds like the telephone mute wire at the back of the set has got trapped and is shorting to ground and it then mutes the radio, remove the set and look for a trapped tel mute wire and wrap insulation tape around it to prevent it happening again
Jan 03, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
Clarion db538rmp
this proble is usually caused by the tel mute cable getting trapped as you push the radio in to the dash, pull the radio out of the dash and see if you can see if any cables have gotten caught in the cage
Nov 25, 2007 | Clarion DB538RMP CD Player
H&B CA-5555 Car CD/ MP3 Player Logo
Top H&B Car Audio & Video Experts
xxxxxx xxx
Are you a H&B Car Audio and Video Expert? Answer questions, earn points and help others
