Question about Motorola Mobility RAZR V3
"Bolt" replacement on Razor Phone
As you know, the Razor is a flip phone. There are two silver "bolts" or hinges will allow the phone to be opened and closed. One of the bolts fell out (and is lost). This makes the flip part of the phone (screen part) loose and wobbly....although the phone still works.
Does Motorola have this "bolt" or do I need an entirely new phone. The telephone was NOT dropped or mishandled in any way. It is in perfect condition, except for this missing piece.
    Scholar:
  • 87 Answers
Be very carefull with the phone. The main cable runs through that left side.
Look on Ebay for a Left hinge pin for the V3. Also knows as the left knuckle.
Make sure you look for the V3. Not Razr.
If your speaker goes out, or you lose display before you get the Knuckle, you need to get a keypad flex also.
If not, get the Knuckle, and it just slides in. MAKE SURE before you pop it in that there are no pieces of the old one in there and that you don't pinch that cable.
I can fix it for you if you send it to our business, but if you're careful, you shouldn't have a problem.
Posted on Jul 31, 2008
SOURCE:
How do I remove the door of Chevrolet spark
This is a TWO person job!
-Open the window all the way. This will give you something to use as a handle.
-Open the door and disconnect the wiring loom connector.
-Unbolt the door check strap bar between the hinges.
-Support the weight of the door and locate the hinge bolt on the door.
-Loosen, but do not remove, on both hinges.
-Get your helper to support the door as it might drop suddenly.
-Remove the BOTTOM hinge bolts first. Then remove the UPPER hinge bolts.
-The door should drop out of position.
REINSTALLING.
-Support the door in the open position.
-Fit the top bolt in the top hinge until finger tight.
-Repeat this for the bottom hinge. It will take some of the weight of the door.
-Refit the lower bolts for both hinges until finger tight.
-GENTLY swing the door closed to check it is not positioned badly.
-Reopen the door and tighten the hinge bolts as follows.
Top hinge, top bolt.
Bottom hinge, top bolt.
Top hinge, bottom bolt.
Bottom hinge, bottom bolt.
-Tighten until tight BUT do NOT overtighten.
-Refit the door check strap.
-Reconnect the wiring loom connector.
-Close the door to check fit.
Jan 23, 2018 | Chevrolet Cars & Trucks
V3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Replace front door Pontiac vibe
THIS IS A TWO PERSON JOB!!
Open the door wide for access. Get a look at each hinge and see if the bolt heads are accessible. If not it will involve stripping door trims and possibly front fenders.
If you can get to the hinge bolt heads, first remove the door check strap across the centre line of the door. This will allow you to swing the door a bit wider making access easier. Wind the window down a short distance as a handle. Then,
SUPPORT THE WEIGHT OF THE DOOR!
Slacken the LOWER hinge bolts leaving them in loosely to act as a brake if the door drops.
Start to remove the bolts in the upper hinge. Get your helper to support the door as it starts to swing loose. Take out the loose upper and lower bolts and remove the door.
To refit the new door, get your helper to hold it in position while you install the top bolt in BOTH hinges. Then install the lower bolt in each hinge. Tighten all bolts to the correct torque.
Lastly, refit the door check strap and close the door to check it lines up.
Jan 12, 2018 | Pontiac Cars & Trucks
There is a clicking noise in the driverside door hinge
It is most likely a loose hinge bolt that allows the hinges to move around when the door is opened.
Mar 26, 2012 | 2004 Chevrolet Tahoe
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
I have a verizon razor but the ear speker went out
This is a common issue with the Moto Razor and can only be fixed by replacing a part. This phone uses different speakers for speaker phone and talk modes.....If you have an old razor laying around that is the same model, you can use its speaker if you believe or can prove it works......otherwise you can buy one for a few bucks. Here is a randomly selected site that sells these parts.
1. Remove the 4 plugs over the screws on the flip top and the screws themselves. 2. pop the top apart and up at the top you sill see where the speaker just sits in there. 3. Replace it the way you saw it in there 4.put it back together Now you can hear your friends without speaker phone!!!
Good Luck!!!! ANd pls rate this post
Oct 13, 2009 | AT&T LG CU720 Cell Phone - Silver
Top flip section of phone broken,
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Aug 14, 2008 | Samsung SCH-u740 Cellular Phone
SCREEN
the hinge is the middle of the phone where the top and bottom of the phone meet think of it this way if u close ur razor the top of the phone is the hinge its the things where it has two shiney cirlces on each sides hope that advice helps thanx.
May 19, 2008 | Motorola Mobility RAZR V3
Razor V3
Take it to the service center, the keyboard cable got broken or worn.
May 03, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
152 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
