Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
I'm having problem using msconfig. I encounter this message when I open msconfig.exe: Windows cannot find ''C:\Windows\System32\msconfig.exe' Make sure you typed the name correctly, and then try again", although the file is actually there. What should I do?
    Problem Solver:
  • 16 Answers
Have you tried using run? Usually windows will find it on its own since System32 is in environmental path.
To do this just hit Windows Button + R and type "msconfig" into the window that pops up.
Posted on Mar 12, 2011
  • ryandolf_d_a Mar 12, 2011
    It didn't work. Still having the same problem.
Everytime I turn on my computer, I get this error message: Error loading C:\PROGRA~2\MYWEBS~1\bar'1.bin\F#SCRCTR What does it mean and how can I fix it? My operating system is Microsoft Vista.
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for "Do not Show this message" and then click on OK.
More on this solution here.
May 05, 2011 | HP Computers & Internet
C windows system32 keyboard services.exe
The virus that cause in action in these system file's is using up of pen-drive's without running an anti-virus check before accessing it,if people's use pen-drive's in like internet cafe's or anything like that.You can wipe it of if you know how exactly find the file in the registry.(The Temp folders should be cleaned out periodically as installation programs and hijack programs leave a lot of junk there. Download CleanUP.).I personally recommend to use Avira Ant-virus or Kaspersky works well and don't slow down the system.
Please find out the URL link.
Hope this Helped!
Oct 10, 2009 | Computers & Internet
Keyboard\service.exe not found error
This is a virus that infected your computer. There is no "keyboard\service.exe" file in Windows. Your antivirus likely removed it but it's still trying to load up on start up.
Go start->Run and type in "msconfig"
Then go to the startup tab on the window that appears and look for that particular exe file and disable it. You shouldn't get the message anymore.
Also clean your harddisk wint an antivirus program
Aug 03, 2009 | Computers & Internet
Genuine hide in windows7
press win+r type "msconfig" without qoute startup uncheck wga then go to registry editer find all wga entry & remove it
restart ur pc, then go to search check hidden and system file in more advance option find wga then delet it if you cant delete this then download a little software called unlocker 1.8 its free & try to search on google you find it after delete wga.exe or wgasetup.exe restart pc now you happy
Aug 02, 2009 | Microsoft Windows XP Professional for PC
CSRCS.exe
My research of that file name indicates it is most likely a trojan of some sort. If it is missing, your antivirus probably removed it.
To remove the message, open MSConfig and goto the startup tab. Uncheck the item associated with CSRCS.exe
If you have windows 2000 you will need to find a copy of MSConfig from the internet.
Good Luck.
Jun 20, 2009 | Microsoft Windows XP Professional
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
WINDOW CANNOT FIND GPHONE.EXE
Gphone.exe is worm which spreads via instant messengers. It usually affects Yahoo! Messenger and Google Talk applications. Gphone.exe send a message and invites victims to visit a website. If clicked upon, the link actually delivers a copy of Gphone.exe infection.
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:\windows\system32).
Go to this website if you need further removal instructions:
http://www.spywarevoid.com/remove-gphoneexe-gphoneexe-worm-removal.html
Jan 21, 2009 | Computers & Internet
Start up msg
First
Open task manager and kill process wscript.exe.
Then
Delete VirusRemoval.vbs and Autorun.inf files from all usb drives.
Delete "c:\WINDOWS\system32\userinit.exe"
Then
Go to c:\Windows\System32 and delete the file VirusRemoval.vbs. It is super hidden so first go to Folder Options and check show hidden and check boxes. Also required for the above files.
Then
go to start>run and type regedit and enter
Go to HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
On the right side look for Shell which should have value of just explorer.exe.
delete anything at right side of explorer.exe if there is anything.
Under same key Winlogon also look for Userinit which should have value of
c:\WINDOWS\system32\userinit.exe,
Delete all the **** after the comma.
Then
Go to HKCU\Software\Microsoft\Internet Explorer\Main
On the right side locate Window Title and delete its value i.e. Sujin.com.np
Under the same key locate Start Page and delete its value i.e. http://sujin.com.np/
then go to Start Menu -> Run -> msconfig -> Startup tab -> uncheck .vbs files
Restart System
Jul 23, 2008 | Computers & Internet
Desktop Error Message
Probably this is a spyware, use a good anti spyware or do the following:
Run Process Explorer (right click on task bar>task manager>Processes) and Kill the Following Processes:
wscript.exe
dxdlg.exe (kill this one first)
Run Autoruns and under logon tab, remove
C:\WINDOWS\system32\wscript.exe C:\WINDOWS\system32\boot.vbs
Search for entries named wproxp and remove it
Remove the following files from your PC:
C:\WINDOWS\system32\dxdlg.exe
wproxp.exe (Most probably in your system32 or windows folder)
Jul 06, 2008 | Computers & Internet
Virus
Hi, there are some xp virus removal visit this site /www.Selecta.site.com
Feb 01, 2008 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
