Question about Nintendo Wii Console
Nintendo wi I HAVE A WIRELESS CONNECTION AT HOME.AN ERROR SHOWS UP IN THE TRYING TO TEST THE CONNECTION FOR THE WII.THE ERROR CODE IS 52031.CAN YOU HELP.
  • Wesley Gardner
    Wesley Gardner May 11, 2010
    what kind of router do you have and have you ever had the wii hooked upto the internet?
    if possible for testing purposes make sure your less then 6 feet away from your wii and your router to connect to the internet.
    the more information you can give the better I can give you some solutions to your issue and get you up and running.
    encryption is disabled and the router is on channel 11.
    or the alternative would be.
    Try calling Nintendo they usually have a good customer service.
    Nintendo System Set-Up,
    Troubleshooting and Repair: 1-800-255-3700
    Problem Solver:
  • 9 Answers
You can try messing with the settings on you router and try it
Posted on Aug 04, 2008
How do i connect my Wii U to the internet
To connect a Wii U to your wireless home network:
  1. From the Wii U Menu, click System Settings.
  2. Using the Left Stick, select the Internet icon and press the A Button.
  3. Select Connect to the Internet.
  4. The Wii U will search for available Wi-Fi networks in your area.
  5. Once the search completes, use the Right Stick to scroll up and down through the list of networks and select the name of your Wi-Fi network.
  6. If prompted, use the on-screen keyboard to enter your Wi-Fi network's security key (wireless password) and select "OK" when finished.
    • If you receive an error message stating The security key you entered is incorrect, the security key you entered was not a valid security key.
  7. The Wii U will now perform a connection test.
    • If the connect test fails, select OK to receive an error code and detailed information on why the connection test failed. You can use Nintendo's Error Code Lookup Tool to get information on resolving the error.
  8. If the connection test is successful, select OK to continue.
  9. When asked if you would like to make this your default connection, select Set if you wish this to be your default connection or No if you do not.
  10. The Wii U will now ask you to perform an update, select "Update" to perform the system update, or select "Cancel" to skip this process.
    • Nintendo recommends performing the system update as this will ensure you have access to recently released applications and services.
Aug 06, 2017 | The Video Game Consoles & Games
Error code 11182
Katie that may be a Wii support code.
Wii Support Code: 11182 - Successful connection test
If you receive a this code, your Wii was able to successfully connect to your wireless network.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wii Error Code Lookup
Nintendo Customer Service Nintendo Wi Fi Connection Support Code Results
Mar 30, 2016 | Nintendo Wii Console
How to set up wireless internet for wii
If it is the Wii console wi fi you are after then go to this site for instructions.
But keep in mind the Nintendo no longer provides support for online network games on Wii. You can still use it in off line mode.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/2679/p/604
Nintendo Wi Fi Connection service for Nintendo DS and Wii has ended...
Sep 07, 2014 | Video Game Consoles & Games
Im trying to download net flix on my wii and im getting the error code 52031...what does that mean?
Error 52031: It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console.
However if you're using Wi-Fi to connect to the internet, your ISP may be blocking the ports allowing you to use netflix from your WII. You may need to contact you ISP in order to verify this problem.
Aug 23, 2011 | Nintendo Wii Console
Trying to connect to netflix trhough the wii console and keep getting a message Error code 52031
It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. For more information about WEP and WPA security, including how to access the settings for your Access Point please visit the following link. (http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterWEPWPA.jsp ).Please rate me as ' helpful ' if satisfied.Good Luck.
Jun 05, 2011 | Nintendo Wii Console
My Wii will NOT connect to my WiFi. I got the error code 52031. HELP!
Error Code 52030, 52031, 52032 WEP / WPA Troubleshooting
nintendo link
May 10, 2011 | Nintendo Video Game Consoles & Games
Trying to connect wii to enternet. Recieved code 52031
This error message is usually due to an incorrect security passcode being entered for your wireless network. Double check and make sure you've got the right passcode.
Apr 26, 2011 | Nintendo Wii Console
Im trying to to connect the internet on my wii like it usally has and for some reason it says on the wii settings 52031 and it dosent connect what do i do ive already tried the key and password so idk what...
It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
Change your wireless router's channel to 1 or 11
Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
Where is your wireless router located?
Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
Look for other devices
Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
If you've tried the above steps to reduce interference and you're still experiencing problems, it's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console.
Apr 22, 2011 | Nintendo Wii Console
Hi normbrus,
According to Nintendo's website, this error usually relates to a security issue in the network. You should try reentering your security settings manually. For a full description of the error code and how to resolve it, visit http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52031&system=Wii&locale=en_US&action2.x=7&action2.y=15.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 31, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
149 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
