My acer aspire one D260 won't charge fully to 100%, stops charging at 91%
I think there is a battery issue or power issue .
let change your battery and charge then see what happened
Posted on Mar 11, 2011
Battery low, dont't start
just a bit of sage advice. most of us men don't bother to read the instruction manuals but I finally did out of boredom. this really works. when you first get your new laptop or replace the battery,competely charge the battery before you use it. then completely drain it or wait the low battery indicator comes on then again plug it in and let it fully charge then fully deplete. patience will pay off. this needs to be repeated a total of three time. I get about three hours out of mine now that I so this.
Mar 21, 2014 | Acer Aspire One D260 Netbook
Acer Aspire One Notebook model A0532H battery wont fully charge
Fully charge battery and if not 100 percent replace.
Nov 23, 2012 | Acer Aspire One PC Notebook
Replaced the power board on acer aspire battery will charge to 28% overnight but charge nlight doesnt lightup
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 22, 2012 | Acer Aspire 4720 Notebook
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
Acer aspire battery critically low but not using battery, it shuts off anyhow
Mar 04, 2012 | Acer Aspire 3610 Notebook
My acer netbook batteries will not charge. Any suggestions?
Nov 08, 2011 | Acer Aspire One D255-2670
I have acer aspire 4741z, when I plug the battery charger, it says plugged in, not charging (6% available). how can I fix this problem? thanks a lot
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Acer Aspire 4730-4947 Notebook
My Acer Aspire one dosent charge completely to 100%, it stops at 87%. I have tried letting the battery run down completely, then starting a new charging process. formally it charges to 100%, then 3 days...
Hello.
From your description, your battery is losing its charge and needs to be replaced.
I'm experiencing charging problems with my own system and I noticed that the A/C adapter is very slightly frayed. So, check your A/C adapter as well and be certain that it is charging when you leave your system charging overnight. If you are still experiencing a problem, replace your battery.
Hope this helps.
Apr 02, 2011 | Acer Aspire One PC Notebook
Acer netbook battery cannot reach 100% charge?
As rechargeable batteries age they build up what is called a 'memory' or a 'charge memory'....
Let me explain how this works...you have a new battery and you run your laptop normally until it hits 15% charge then you charge it up and use it again until about 15% then charge it again....with the charge only dropping to 15% the battery builds up a 'memory' of that over a period of time (usually over at least a year up to a couple years) and then your battery's maximum capacity is no longer 100%. Same thing happens if you dont charge it fully each time, after a while it becomes incapable of taking a full charge.
What you can do to stop that in the future....when you get a new battery every now and then run its charge down to 1% then charge it to maximum. By doing that on a regular basis you help make sure the battery remembers its full charge capacity.
Feb 19, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
Help on extending the battery life of my acer aspire one!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
The only solution is a new battery.
Dec 26, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
