Question about Microsoft Kinect Sensor for XBOX 360
My kinect keeps turning off. i play for less than 30 minutes and then it'll shut off. I have to unplug it and plug it back in for it to work again.
3 Suggested Answers
SOURCE: Turning on and off randomley
hi
i had this problem but then i realised it was completely to do with te way i had hoked it to the tele
if you get the main power suply and turn i round by the wire 3-7 times will on a game it will work perfectly
hope that this helps
Posted on Dec 31, 2008
SOURCE: 2 red lights. Fans don't help
you have to take the x-box apart(youtube) and then take off the heat sinks clean the thermal paste apply new thermal paste remount heat sinks with type 5mm screws and m-5 washers, nylon not necessary. after remounting the heatsinks you have to overheat the system and then let it cool. the overheating process will sometimes require a heat gun since the console will not stay on long enough to get it heated properly. you sometimes don't have to do this if reapplying new thermal paste has done the trick.
Posted on May 10, 2009
Kinect is acting up and not recognizing my voice or commands
Don't worry, you're not the only one with this problem. A common solution is to dump your memory on the Kinect (which was probably corrupt accidentally by the update). In order to do this, you need to go into the settings on your kinect and power it off, then shut down the console. After this, you must unplug the Xbox from it's power source and wait about 30 seconds for the internal power to shut off. After that, it should work perfectly, otherwise your kinect may be faulty and subject to repair.
Feb 20, 2014 | Microsoft Xbox One
My kinect does not turn on the light stays on red
Try unplugging the kinect and then the x-box power for a few minutes. Then plug the kinect in before reconnecting the power. If that doesn't work you may have to contact microsoft support, there should be a phone # on the package.
Sep 11, 2011 | Microsoft Kinect Sensor for XBOX 360
Xbox kinnect keeps shuting down, less than 5 minutes into loading and/or playing the game.
  • Make sure your kinect is correctly plugged in to your Xbox
  • Make sure your Xbox power cord is plugged in
If problems continue it is because there is a problem with the kinect sensor. Having the kinect automatically turn off has become a common problem for many users. Try returning your sensor to the place of purchase and get a new one. Seeing as it is a known problem the store will likely understand and give you a full refund.
Jun 12, 2011 | Video Game Consoles & Games
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Blinking error codes?
Unplug the machine for 30 minutes , plug it back it, start it for 1 minute, unplug it again for 5 minutes then plug back it and it should work. If not then write back with the error codes so further diagnostics can be done
Apr 08, 2009 | Kenmore 62602 Electric Dryer
The Kenwood VR517 home theater system wants to just turn itself off at about 5 minutes of being on. this just started happening this week.
If this unit stays on for 5 minutes, and it appears to be playing normal, a bad speaker could be the cause unless you are using speakers that are not compatible with this unit.
The specs on this unit are 100 watts per channel and require 8 ohm speakers. if you are using speakers that are 6 ohms or 4 ohms, you will overheat the unit quickly and it will shut down. It is not designed to use anything less than 4 ohm speakers.
If you are using the speakers this unit came with, or you know that the speakers are 8 ohms (it should be listed on the speaker where the wires plug in), go ahead to the next step.
The first thing to do is to unplug one speaker, it does not matter which one, just pick one to unplug from the back of the receiver or right at the speaker. If you unplug one right at the speaker, make sure that the speaker wires do not touch together or touch anything else, they must be insulated from anything metal or conductive.
After one speaker is unplugged, turn the unit back on and let it play normally the way it was when it shut down after five minutes. If the unit continues to play for a long time, at least 30 minutes or more and does not shut down on its own, you have just found the culprit causing your problem. Some speakers may sound like they are OK, but still can cause a problem.
If the unit shuts down again after five minutes like before, go ahead and plug that speaker back in and do the same thing with one of the other speakers.
Continue this process until you have isolated one speaker as being the problem.
If you go thru the entire process and it still shuts down, you may have an internal amplifier problem. It can be something as simple as some heat stressed solder joints that need to be reflowed, or it could be a bad amp IC. This unit uses 3 different amp IC's and it could be any one of them or a component in the amp circuit. Sometimes it can even be a power supply failure. In any case, if the above steps do not work, you need to take it in and be serviced. There are no other end user options to perform.
I hope this helps with your problem, if you need more help just ask.
Jun 21, 2008 | Audio Players & Recorders
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Microsoft Kinect Sensor for XBOX 360 Logo
631 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
